Question about Tablets & eReaders
When I press the L key my Bush tablet switches off. How do I stop this? Thanks
My tablet has been playing up since getting a new rooter, keeps saying unfortunately facebook has stopped, also just switches itself off, no warning
seems as if its not the issue with the new router you have but rather an issue with the tablet itself at a android system level try resetting the tablet's android software in the recovery mode (press and hold the power key and volume up (or down or in samsung tablet cases power, volume up and home keys must be pressed at the same time if the tablet vibrates let go of the power key and hold just the home key till the recovery menu pops up)
Feb 24, 2017 | Tablets & eReaders
I forgot my Acer tablet pin.What do I do
Power off the tablet.
Press and hold the Volume up button, which is located closest to the touch screen lock switch.
While holding the Volume up button, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
Once the tablet screen turns on, stop holding the buttons.
On the Android system recovery <3e> screen, select wipe data/factory reset. Use the Volume up and Volume down keys to navigate through the menus and use the Power button to select the desired option.
When prompted to "Confirm wipe of all user data", select Yes -- delete all user data.
Select reboot system now.
Mar 21, 2015 | Acer Tablets & eReaders
My tablet switched off during a game and won't come back on. Bush hdmi
Did you try charging the battery? and a reset, after charging?
Jan 14, 2015 | Tablets & eReaders
I have a bush mytablet 7" tablet and it has totally crashed i cant even turn the tablet off can u help Many thanks Crystal
don't know this one but if you look carefully there should be a tiny little hole just big enough for a paperclip to be inserted. gently insert and apply just enough pressure to feel a small click, this should reset the tablet. good luck
Jun 28, 2014 | Tablets & eReaders
Sccreen says all systems, ie, keyborad,google etc have stopped
Most tablets available nowadays are Android-based ones. And most of them can be "factory reset" to leave them as brand new.
First, understand that if you continue, all the information you already added to your tablet will be erased. If you have any info you need to retrieve, please, do not go on and try something different, OK?
All right... Let's go on... The best way to know how to factory reset (or "hard reset", as it is also called) your device is to check in the Internet if there is already a description of the whole process. Assuming that you have a Samsung Galaxy Note 8 tablet, search in Google for "how to factory reset a Samsung Galaxy Note 8 tablet?" Follow the instructions and you will have your tablet running as if it had just been taken out of its box!
If you cannot find the instructions for your specific device, you could, then, try to check if it can enter recovery mode. First, completely switch off your tablet. Then, press at the same time and maintain pressed the "Power" button and the "Volume Up" button and wait for the device to power on, when you can release the keys. An "Android System Recovery" page should appear. If that is the case, you can navigate through the options using "Volume Up" and "Volume Down" keys. Go to the "wipe data/factory reset" option and activate it, pressing the "Power" button. Your tablet should reset (it will take a while).
If you didn't enter the reset page with those keys, repeat the process, this time pressing "Power" and "Volume Down" keys (different tablets have different combinations of keys to enter recovery mode.)
Hope you may find this information helpful!.
Dec 05, 2017 | Mach Speed Trio Stealth G2 Tablet -...
My Sungale ID706WTA tablet is crashing. Every time I power on the tablet the error notification keeps popping up saying the Launcher has unexpectedly stopped. I have to keep hitting force close a billion...
Factory Data reset / Hard reset
  • Switch off the tablet.
  • Press and hold the Power and the Volume Up keys.
  • When you see the logo, release only the Power key. ...
  • From the Android recovery menu select one by one:
  • - wipe data/factory reset.
  • - Yes -- delete all user data.
  • - reboot system now.
Nov 22, 2017 | Sungale ID706WTA Tablet
Have the dragon touch 10.1" hd tablet everything in Chinese how do I switch it to the English language
If is itunes compatible just hook up to computer running: tunes/ if not can do reset by pressing volume up key, home key, and power key holding till reset screen appears.
Mar 01, 2013 | Tablets & eReaders
Tablets & eReaders Logo
48 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
