Question about Health & Beauty
Jazzy 1133 blows 7.5 amp fuse after a minute or two of batteries, chair hasnt been used in several years
  • 432 Answers
SOURCE: always blows fuses
I would get a volt/ohm/continuity meter to test the connections. You have a short somewhere. You can take it Car Auto or Tweeter and they can check it for you. Some of these places charge a $35.00 diagnostic fee. If you have a schematic diagram, you can test where the short might be.
Posted on Apr 09, 2008
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 692 Answers
SOURCE: jazzy 1121 power chair won't charge when plug in
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Posted on Oct 23, 2010
  • 5 Answers
SOURCE: Jazzy 1121 power chair won't go
I find a lot of the controller Problems are caused by the cable running from the joy stick down to the controller gets caught on something or rubbed against something and one or more tiny wires inside are broken ... If I find a spot on the cable that is worn through, that's where I start .. Open up the insulation and check the tiny wires .. fine the broken one and repair it .. usually that solves the problem and saves you a couple hundred for the cable
Posted on Oct 08, 2011
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
Jun 20, 2012 | Pride Jazzy 1103 Ultra Standard Power...
1143 jazzy wheel chair new batterys @ new charger still not charging
With a new charger and new batteries there can only be one other problem assuming all the wiring is connected properly. There is a 7.5 Amp in-line fuse hidden in a fuse holder off the charging harness. This fuse may have blown. I usually check this fuse first since it is usually the culprit and most difficult item to locate under the back cover. In rare cases the ammeter burns open and will cause the unit not to charge. After checking the fuse you can jumper one or both these items to see if it will charge and then purchase new parts. Hope this helps.
Apr 16, 2011 | Select Jazzy Used Electric Wheelchair
Jazzy Select 6, Charge batteries. Green light comes for a few seconds and goes directly to red light. Chair will continue running. One battery shows a charge of 12 volts the other 13 volts. Has...
Hi You need new batteries If you have a battery store near home or an interstate battery distributor have them get you 2 U1 batteries. Charge before use and you should be go to go for another 3 years or so Hope this helps
Feb 10, 2011 | Pride Jazzy Select 6 Indoor Power...
I have a Jazzy1113,it had been unused for several years.I did not take right steps to take care of batteries. I tryed several months ago to start and of course would not,but i do remember some movement...
There is a 7.5 Amp ATO automotive fuse on the rear electronics tray that is probably burnt out. The ammeter will not work when this happens. Also, if you have a bad on-board charger that will inhibit movement of the chair. Unplug the on-board charger and see if you get it to move. Hope this helps.
Jan 04, 2011 | Pride Jazzy 1113 ATS Indoor Power...
I have a Jazzy Power Chair that hasn't been in use for several years. When I tried to charge the battery only the red light comes on. How do I get the yellow light to come on to show it is being charged?
Retired get new batteries if they haven't been charged for that long they're shot. Invest in 2 good U1 batteries, charge before use and you should be good to go Good Luck
Nov 01, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy select hasnt been charged over a long period and now batteries are not charging manuel says they may not charge to call provider what will be done can they be charged again?
Virginia sorry no. Your charger cannot pickup low batteries and charge them. You will have to purchase 2 new U1 batteries. If Medicare purchased your chair then they will pay for most of the cost of new batteries. If you bought the chair then I would look for a battery warehouse type store or an Interstate battery store and buy them there they would be somewhat cheaper than buying them from a provider. Hope this helps you
Sep 11, 2010 | Pride Jazzy Select 6 Indoor Power...
Jazzy 1103 will not charge. Power cord and electrical outlet verified good. Plug in chair for charge, the ammeter indicator bar remains at 0, even after several minutes. If chair is powered on (while...
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
May 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
29 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
