Question about Maytag Refrigerators
How do I remove the ice maker in the Maytag Plus side by side MZD2752GRQ? My fill tube appears to have a greenish-black substance growing out of it and the ice has green clumps in it.
peyton32034
  • 410 Answers
SOURCE: Maytag ice maker wont fill upwith water
is the icemaker cycling at all? pull the front cover offf of the icemaker and verify that the gear isnt broken. if so replace the motor module. if thats ok the next 2 things could be either a frozen fill tube or bad fill valve..
Posted on Dec 12, 2007
SOURCE: Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Posted on Aug 10, 2008
SOURCE: Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
Posted on Sep 15, 2008
  • 149 Answers
SOURCE: Ice maker water tube keeps freezing
u can replace the plAstic one with a copper one
Posted on Oct 27, 2008
SOURCE: Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Posted on Apr 12, 2009
Maytag model MZD2766GEW. The water tube supplying
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jun 28, 2011 | Maytag MZD2667HE Side by Side Refrigerator
I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
May 20, 2011 | Refrigerators
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice maker stopped making ice and now is leaking from the back of the fridge.
Here is what I think it might be: The water valve has a slow faucet like drip that forms a stalagmite in the fill tube. When the ice maker calls for water the water goes out the backside. OR it might be the line has a hole in or has come off the fill tube in back of the ice box. Solution: replace water valve and blow dry fill spout to get out ice.
Apr 01, 2010 | Maytag 24.8 Cu. Ft. Side-by-Side...
Not making ice . LED is flashing properly and put power to the valve in the back of the unit and it pushed water so appearantly something is not tellng the valve to open
Check the short black tube that is above the icemaker fill cup , to see if it is frozen . If so , then the water valve is " seeping " . Not closing completely and letting drops go thru which freezes in the tube . After a while , even if the ice maker calls for water , and the valve opens , it cannot fill the ice maker due to the frozen tube . Turn your freezer temp down , after removing as much ice from the tube as you can ( hair dryer may help ) . May take several days to thaw , since the tube runs between the top freezer liner and the outer cabinet . If not frozen , then the icemaker is bad .
Oct 13, 2009 | KitchenAid KSRU25CR Side by Side...
Ice maker does not make ice. Arm is in proper
Pour about 1/2 cup of water into ice maker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure thefridge coils are clean and free of dust , lint , pet hair , etc....
Aug 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
Feb 07, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Refrigerator leak
May 20, 2008 | Maytag MZD2766GES Side by Side...
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
