Question about Refrigerators
Front ice panel not lighting - Refrigerators
I just connected the ice maker water line to the unit. The Frig has electrical power and ice is making. My problem is that the controls at the front of the Frig is not working. I cannot dispense the ice...
Without a model number here how they usually operate. The DOOR / LIGHT switch disables water and ice in door functions. I.e. it is not supposed to operate with the door open. If the switch is open... i.e the light is not working door open, (Switch has 2 functions Light and Water / ive in door operation) Then the control panel / water / ice in door will all not work either. It is possible for the light to work while the CP / H2o / Ice do not work. Usually if a door switch fails the light stops working also. It is not always the case.
Try holding to door switch plunger depressed and see if your CP works and water in door work. DO NOT try ice in door as you can damage things.
If you respond with a model number and brand; I will see what I can dig up for you use while troubleshooting your unit. Expect to see parts data also.
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | Refrigerators
When machine is first turned on it will run till bin is filled and it cuts off, but will not restart after ice is removed from the bin.This os a hoshizaki commercial ice machine
Remove front panel, look at controler,(where the blinking lights are) there should be a sticker on the back of the panel that tells you what the problem is by how the light flashes. IE- if light flashes 2 times, stps, flashes 2 times,etc, etc
Oct 08, 2010 | Microwave Ovens
No water,light, or ice on the door
The control panel is most likely at fault. They are all controlled by the panel. Very rare for all 3 devices to go faulty seperately
Aug 27, 2009 | Freezers
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker and water dispenser front panel lost power
Check the power connection for the door.. It is either under the hinge cover on the top or under the kick plate in the bottom.. Just un plug and re plug if it seems like the wires are fine
Good luck
Feb 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice & water dispenser not working
The control board is likely gone bad or a wire harness inside the front came loose. With all those indications, I'd lean toward a dead board.
Jan 07, 2007 | GE PSW26SGRSS Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
