Question about Sanyo Televison & Video
How to retrieve a link code from a sanyo tv to display utube from internet phone
Can you give me the codes for a sanyo tv for a universal remote
try this link...4 digit GE codes for TV sets including LCD, Plasma, and Panel TVs Brand Code SANSUI SANTECA SANYO SCOTCH 224 more rows
4 digit codes for TV sets including LCD, Plasma, and Panel TVs - GE ...
www.eliztech.com/remotes/ge-4digit-tv-codes.php codes for sanyo tv for universal remote Google Search
Dec 09, 2016 | Sanyo Televison & Video
What is the remote control code for a TV Sanyo Model #DS25204. It is a Sanyo remote control
0281,0229. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Apr 20, 2015 | Sanyo Televison & Video
Sanyo fxwd
Programming procedure to this remote control is given in detail by this link. http://electrohelponline.blogspot.com/
Try these links too. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
Aug 15, 2013 | Televison & Video
NEED A CODE FOR A SANYO CRT TV WITH A SANYO REMOTE
0854,0347,0223,0548,0532. Try these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Panasonic Televison & Video
I need the code to my sanyo tv
Hello
According ro RCA Codes for sanyo are detailed as
Code 004 for sanyo tv Code 048 for Sanyo TV Code 049 for Sanyo TV Code 073 for Sanyo TV Code 080 for Sanyo TV Code 107 for Sanyo TV Code 162 for Sanyo TV Code 169 for Sanyo TV Code 180 for Sanyo TV Code 196 for Sanyo TV
Just check with these codes according to the proceedings.
1. Manually turn on the TV.
2. Locate the enclosed TV Code List. Find
your brand of TV.
Note: If your brand is not listed, use one
of the Code Search methods to program
this remote control. (See section on
Code Search.)
3. Press and hold the CODE SEARCH key
until the indicator light illuminates.
Then release the CODE SEARCH key.
4. Press and release the TV key. The indicator
light blinks and then remains lit.
5. Use the number keys to enter the first
code listed for your brand. After you
enter a valid three-digit code, the
indicator light turns off.
Note: If you enter an invalid code, the
LED flashes rapidly for two seconds.
Start over at step 3.
6. Aim the remote at your TV and press
the ON•OFF key. If your TV turns off,
you have found the correct code.
7. Enter the code in the box provided on
this page for future reference.
8. If your TV doesn't turn off, repeat steps
3-6 above, entering the next code for
your brand.
Manual Code Search
1. Manually turn on the component you
want the remote to operate.
2. Press and hold the CODE SEARCH key
3. Press and release the component key
that corresponds to the component you
want the remote to operate (TV, VCR,
DVD, DBS•SAT, CABLE, AUDIO). The
indicator light blinks once and then
remains lit.
4. Aim the remote at the component. Press
the ON•OFF key continuously until the
component turns off.
Important: Because there are so many
codes, you may have to press the
ON•OFF key many times-possibly up
to 200 times.
5. When the component turns off, press
the ENTER key to store the code.
6. Use the Code Retrieval section on the
next page to identify the code for your
component for future reference.
OK
Feb 15, 2011 | RCA RCU600M Remote Control
Accidentally set tv to display what appears to be closed captions during a program, not commercials - in Spanish, not my language - when searching for a way to have closed captioning. It displays on only...
You have a setting on the SETUP on your remote. You have the option to use English or Spanish. Somehow, you must have accidentally changed the language. I did this on one of my TV's.
Just go through the setup again.
Hopefully this will solve your problem.
Jan 09, 2011 | Sanyo Televison & Video
How can I transfer the photos from my Sanyo 3810 cell phone to my Apple I mac? Also, can these photos in the Sanyo phone be displayed on my tv?(which has USB ports)
Hello
Firstly, you can transfer your picture using bluetooth. Activate bluetooth on Apple I mac phone and send the picture from Sanyo 3810.
Secondly, You can remove the memory card on the Sanyo 3810 and insert it on Apple I mac phone.
Photos in the Sanyo phone can not be displayed on tv it can only be displayed on computer using your USB ports and connecting the laptop and the Sanyo phone with the USB code.
Take care,
Sep 16, 2010 | Sanyo Cell Phones
Can i retrieve deleted text messages from the sim card of a sanyo scp-7050
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Oct 07, 2008 | Sanyo SCP-7050 Cellular Phone
Sanyo 8200
Call your carrier for assistance. usually it is the last 4 digits of your phone number. However, if somebody has set a code on it... you might be able to go online to retrieve the info. I would FIRST call your carrier they may have a simple fix.
Dec 20, 2006 | Sanyo PM-8200
Televison & Video Logo
59 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
