Question about Hardware & Accessories
I have a Defiant Indoor Basic timer, 49829, that I want to install.
I removed the old single toggle switch, then connect the wires (ground, white-white, red-red, black-black). While the timer can turn the light on and off, it does not keep time (i.e., the dial does not rotate). Suggestions?
  • 71 Answers
SOURCE: Help - I am trying to install a honeywell RLV4300A
You will have to have schematics from the old wiring diagram. Then you will have to confirm its consistency with actual old wiring before you can be sure that the wires run to the proper places on the old heater and a/c system. This sounds like a gas furnace and is simpler than a heatpump. Once you know what distinguishes the wires with the same color, you should label them and then you may call them a different color if they were wired with wrong wire colors. You may be in luck if you go to the furnace control box an look at the terminals.. They are usually labeled with a R for Red and W for white and Bl for Blue and B or Black. If you have other colors on these then it sounds that it was wired with wire spare wire by someone who knew what they were doing but neglected to leave a path for someone else follow.
You may be able to use a continuity tester of circuit tester to id these wires that are in question...
ie, once indintified, you can match with the requirements of the new stat.
Posted on Jan 13, 2009
SOURCE: Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
Posted on May 11, 2009
  • 12744 Answers
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Posted on Feb 22, 2010
  • 351 Answers
SOURCE: I bought a Utilitech 7 day digital in wall timer,
HI .. if the switch has only a black and white wire attached, and there are no other wires in the wall box, then you cannot use this timer switch. You need to return it and get a timer that does not use a neutral connection. The wires you have are a switch leg from the light and there is a white wire but it is not a neutral.
If there are other wires in that wall box , tell me and we can chat more about how to remedy this .
Please Vote !!
Posted on May 25, 2010
  • 2841 Answers
SOURCE: I have purchased a Utilitech
What you have a single pole light switch you are replacing with the timer. As you say you have 2 black wires. One black wire is the incoming power wire and the other black wire goes up to the light. On a normal single pole switch is makes no difference which of the screws you connect it to. Of course with the exception of the ground screw. Tie all the white wires back together that are in the wall box and shove them to the rear as they are not needed to make this connection. The correct connection is to connect one of the black existing black wires in the wall switch box to the black wire on the timer. Now connect the other black wire to the blue wire on the timer. The red wire is not used in a single pole connection and is only used in a 3 way switch connection, so just put a twist connector on it and shove it back in the box. To recap, connect black wire on timer to either black wire in box. Connect the other blue wire to the other black wire. Do not use the red wire. Hopefully you did not hurt the timer by connecting it incorrectly. If it does not work after setting the timer up according to the instructions you have ruined the timer by wiring it incorrectly. Hopefully no damage has been done.
Posted on Aug 14, 2010
Lost manual to program defiant daylight adjusting indoor digital timer
videos and text manuals.
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer ...
? 16:31
https://www.youtube.com/watch?v=yxZKNVddNU0
Jun 24, 2015 - Uploaded by Jasco Products Company
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer. Jasco Products Company. Loading ...
Defiant Daylight Adjusting Indoor Digital Timer with Motion Sensor ...
https://www.homedepot.ca/.../p.daylight-adjusting-indoor-digital-timer-with-motion-s... Easily automate indoor or outdoor lights with the Defiant Daylight Adjusting Indoor Digital Timer. Program up to 7 on and off times per week. Auto adjusts to ...
DEFIANT 469-637 QUICK START MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Defiant Manuals > Timer View and Download Defiant 469-637 quick start manual online. DAYLIGHT ADJUSTING INDOOR DIGITAL TIMER. 469-637 Timer pdf manual download.
[PDF]Home Depot Defiant Timer - A-1 Electric Co., Inc.
www.a-1electricco.com/technical/timers/defianttimerprogramming.pdf We appreciate the trust and confidence you have placed in Defiant through the purchase of this daylight adjusting indoor digital timer. Visit us online to see our. defiant daylight adjusting indoor digital timer Google Search
Mar 13, 2017 | Hardware & Accessories
Does the Defiant Daylight Adjusting Indoor Digital Timer also uses a battery?
No battery.
This single-pole or 3-way, programmable or dawn-dusk timer is same as GE 15312 sun smart timer, and requires a neutral wire to power the electronics.
GE renamed all their wall timers, or sold their timer business to Defiant in year 2013-4.
http://waterheatertimer.org/Programmable.html#15132
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you want a timer with same capabilities, that uses a battery, and does not require neutral wire, then choose Intermatic ST01 or Ei600 timer
http://waterheatertimer.org/Programmable.html#st01
Gene
Water Heater Timers Save Money
Dec 05, 2014 | Hardware & Accessories
Defiant digital timer has blinking light
Installed a Defiant light timer today. Light came on as scheduled, but is blinking. When I attempt to "toggle" OFF, it only dims, does not go OFF. When I move the switch from the ON to the OFF position, the unit turns the light off. Defective timer? HELP !!
Aug 14, 2013 | Defiant Timers: 5-Amp In-Wall Digital...
I have the unit wired and it does not wotk.I have black to black,red to red green to ground and white to white,any thoughts? Thank you
Electrician test wiring before connecting anything.
First of all, you don't mention what type of switch was replaced.
1) Leviton 6230 countdown timer is made to replace single-pole light switch only.
Single pole is where 1 switch controls the Load (light fan motor)
Your wiring sounds like 3-way switch.
3-way is where 2 switches control same Load.
For example a hallway usually has 3-way switches.
To confirm. If old switch has 1 dark screw, 2 brass screws, and 1 green screw, then that is 3-way switch. Use Leviton LTB15, LTB30, LTB60, LTB02, LTB12 countdown timer for 3-way.
Smarthome sells product and shows .pdf manual
http://www.smarthome.com/4255/Leviton-LTB60-1LZ-4-Button-10-20-30-60-Minute-Countdown-Timer-Switch/p.aspx
2) If old switch has 2 brass screws and 1 green screw then that is single-pole switch.
3) If you are replacing single-pole switch, here are testing & wiring instructions for Leviton timer.
Remove device and separate wires for testing.
Use ordinary two wire tester.
Tape tester leads to wood sticks so hands are away from power.
Do not untwist wires that were twisted together before you started.
Turn on power.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire will connect to timer black wire.
Now you know Hot wire.
Test Hot wire to each of the other wires, excluding bare ground wire.
Tester lights up on neutral. Timer white wire connects to Neutral wire.
If box does not contain Neutral wire, then timer white wire connects to bare ground.
Timer green wire connects to bare ground wire.
Timer red wire connects to wire going to Load.
Dec 26, 2010 | Leviton 6230M Decora Four Preset...
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
OLD wall timer Model E1020 ticks really loud
You probably can't get the existing mechanical timer to operate any quietier, since it's old and likely starting to wear out. You can either swap the timer out for a new automatic digital timer, or install a standard single pole switch in its' place.
I believe the code you refer to regarding the fan having to be wired onto a timer switch was a local requirement from many years ago.
Some local jurisdictions have impossed more stringent requirements, but frankly, having an exhaust fan is normally a good idea. If the fan is vented into the attic space, it can cause some serious problems in cold weather with condesation of the warm, moist exhaust air.
Building Code requires that bath fans be piped/vented to the outside of the house and not into the attic space.
There are newer preset timer switches that will turn on the exhaust fan for a fixed amount of time, based on which button you push. These are great as they will run the fan long enough to remove condensation from showers, etc.
If you're going to replace the timer, disconnect or turn off the breaker or power to the switch. Then simply install a new timer or switch by connecting the black supply wire to the bottom of the single pole switch, or to one of the black leads of the timer. Then connect the black wire going to the fan to the top screw on the single pole switch, or the other lead on the new timer. The white (neutral) wires should already be connected with a wire nut inside the box. Connect the ground wire to the ground wire in the box and if the switch box is metal, attach the ground wire to the box with a green grounding screw too.
You can now operate the fan with either a manual on/off switch or the new digital timer, whichever you chose to install.
Sep 04, 2009 | Heavy Duty Intermatic Wall Switch Timer...
Hardware & Accessories Logo
85 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
