Question about Garden
I bought a brand new 31cc yard teller but won't start. I followed all 3 steps gas is mixed properly but still nothing
  • 40 Answers
SOURCE: Troy-Bilt Trimmer won't start
try taking the carb off and you should find 2 adjustment screws on it. turn those in until they stop, do not force tight. while doing this be sure to keep and eye on how far you turn them in. they likely wiil be set at 1 1/2 turns. now that you have done this unsrew them all the way out and get some carb cleaner to spray in there and rinse any old or dried up gas out. then replace the screws at the same setting they were before you took them out. this should take care of it.
Posted on Mar 11, 2009
SOURCE: Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
Posted on May 18, 2009
  • 22 Answers
SOURCE: what is the ratio of gas and oil mix for a ryobi 31cc trimmer
just use about 3 to 4 ounces of 2 cycle oil per gallon and you should be fine. a little extra lubrication wont hurt it
SOURCE: Brand new Homelite Mighty Lite 26cs String Trimmer
carb setting is too lean,need special tool to open,go to mower shop.This model also has problems with starter mechanism,I hope you have a warranty
Posted on Jun 14, 2009
  • 130 Answers
SOURCE: MY RYOBI 31CC 775R WEEDEATER WON'T START I
spary a little startingfluid in carb to see if it start if it start rebuild carb.to change fuel line
only if there dryrotted if it go thourght the gastank in little hold cut new line on a angle and thread through hold.hope helps you.let me know ok
Posted on Jul 25, 2009
HOW TO REPLACE DUAL LINE ON GRASS TRIMMER
search google for "YARD MACHINE 31CC GAS TRIMMER Manual". the manual is there I have seen it. also check youtube.com
Hope this helps...
May 01, 2016 | Yard Machines Garden
Tiller won't start. brand new
did you mix proper gas and oil. check or replace plug and check for spark
Apr 21, 2013 | Ardisam Inc Earthquake Mini Cultivator
Brand new and staling
Is the choke leaver in the off position when warmed up? Have you used correct fuel/oil mix?
Jun 26, 2012 | Husqvarna Forest & Garden 125c 17"...
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
I have a new[purchased last summer] Yard Man Mdl.: YM320BV 2-stroke, 31cc, blower/vac that will not start. Fuel is fresh, has new spark plug (what should the gap be?) original plug was...
If the plug is black then either there is too much two - stroke oil in the mix or the gas / air mix is too rich due to e.g. dirty air filter. Have a look at these tips for starting weedeaters, they apply also to blowers:
http://www.fixya.com/support/r9230929-weed_eater_strimmer_will_not_start
Jun 09, 2011 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
I have a gas operated 31cc Craftsman model number 316.798221 weedwacker trimmer 17 I mixed fuel with 2 cycle engine oil using a 4 to 1 ratio. The trimmer no longer starts. It seems as if it is about to...
If you have mixed your gas and oil to a 4 to one mix you have way too much oil in your gasoline. Drain out your fuel tank and carburetor. ----------------------------------------------------------------------------- Remove the spark plug and clean if necessary. Mix your fuel in a fuel container at 40 to one. Some sites even recommend a 50 to one mixture. (50 to one mixture is one pint of oil to 6 gallons of gasoline) Refill your fuel tank on the trimmer and try to crank, if it does not want to crank within 4-5 pulls then you may want to give it a very small shot of starting ether in the carburetor intake and try to crank again. Good Luck, I hope this helped, Please rate me, Thanks
Dec 30, 2009 | Garden
May 16, 2009 | Mtd Garden
Ran gasoline in 2 cycle engine and it will not start now Put 100% gas (no oil mix) in 2 cycle engine. Ran for 3 minutes and stopped, will not start now. Engine not seized but will not start.
Hello:
Remove the Muffler and Look into the Exhaust Port.
If the Piston has Scratches or Gouges, then the Engine is Trashed and will have to be Replaced.
A New Unit is Usually Cheaper than Buying the Replacement Parts.
You can View a Breakdown of this Unit at the Following Site Addy.
http://www.smallenginepartswarehouse.com/parts.asp
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Troy-Bilt Blower/Vac 31cc, 200 MPH, 405...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
