Question about Samsung Dishwashers
I have an over-level water check code flashing. What can I do? This is for a samsung dishwasher dw80j3020us
2 Suggested Answers
SOURCE: over-level water error
I finally found the cause of my "over-level water error", and I fixed it. In my case it was a gummed-up water level float chamber (part #13 in the diagram here). Once I pulled it out, cleaned it, and put it all back together the dishwasher is running fine. What follows are the symptoms I experienced, and some pictures of what I saw and did to fix it.
Symptoms: After nearly 2 years of owning a DMT400RHS, dishes began to progressively come out with sediment on them. They were not being cleaned nearly as well as previously. This symptom seemed to start fairly suddenly and remain for about 2 months. Then, the dishwasher began to occasionally error out, first with "Drain Error" or "Over-level water error", then later consistently with the "Over-level water error":
For awhile we could just restart the dishwasher and it would do a load. Later, however, no matter how many times we restarted, unplugged, etc. it would not continue. Of note, there was never actually a drain problem, as it would always, well, drain.
The error was never triggered during the initial "drain phase". It was always triggered after that phase, when it was filling the tub with water, specifically after it had been filling for awhile. Eventually, we figured there must be a float someplace that was all gummed up and not moving up with the water level.
Well, here's what I found when I finally pulled the entire dishwasher out and laid it down on its side (facing the door, tip it over to your right):
Inside that little box with all the sediment and glop is a wing-shaped float that couldn't move due to the glop. I simply held the whole plastic thing under the sink faucet to rinse it out. I had to take off the tub pan in order to pull off the drain hose that's attached to the back of this chamber. After rinsing it out, I put it back in and the dishwasher seems to be running fine:
Posted on Apr 21, 2013
Is there a fuse for a samsung dishwasher DW80j3020us
page 22 owners manual.The unit does not have a fuse.
qaaaaasuvork5cyiia
Apr 18, 2018 | Samsung Dishwashers
Wear is the reset button on a samsung DW80J3020US dishwasher?
They don't have one. Disconnect the power, count to 10 and plug back in.
Oct 03, 2017 | Samsung Dishwashers
Dishwasher starts and then stops with 9E flashing in window.
The 9E issue indicates a low water level in the dishwasher. Check your hoses. Make sure that no dishes flipped and filled with water. Make sure that the dishwasher is level. Next check if there is any debris blocking the water level (overflow) sensor. It's in a small square plastic box on the left side of the dishwasher. Pull the dishwasher forward and check for loose or damaged wires to the water level sensor.
If the wiring is good and the error persists, replace the sensor. Replace the wiring if it is damaged. If you add a comment with the model number, I may be able to point you to the replacement part. If your dishwasher is under warranty, contact Samsung for the repair.
I hope this helps.
Jul 04, 2016 | Samsung Dishwashers
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
What could be the problem on my Samsung DMR57LFS dishwasher with an E9 error after the low-level sensor is cleaned but the error still exists?
I have a Samsung stainless steel tub dishwasher and only 2 months after we had it installed we had all sorts of issues with it. We were lucky it was under warranty and turned out parts needed to be changed - upgrades from Samsung that were not done i nthe store where we purchased the dishwasher.. You may want to check with Samsung with your Mode land Serial Number you never know, there might of been a recall. Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Sep 15, 2014 | Samsung DMR57LFS Stainless Steel Builtin...
What is a E3 code on Samsung dishwasher
The E3 error code on Samsung dishwashers is due to the overflow water level being abnormally high inside the machine, this is caused by a blocked pressure system. Start by checking the supply hose for kinks and restrictions.
Jan 20, 2014 | Dishwashers
Low water level sensor
Thank you, worked like a charm. So simple. It needs to be done annually, as a regular maintenance...
May 29, 2012 | Samsung DMR78AHS Builtin Dishwasher
Dishwashers Logo
623 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
