Question about Element Televison & Video
Black screen on element hdtv - Element Televison & Video
2 Suggested Answers
  • 11361 Answers
SOURCE: Element 32" LCD HDTV 4
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 25, 2011
Led light blinking
It is likely that the internal power supply has failed.
Dec 08, 2013 | Element Electronics Element 40" LED 1080P...
Picture went black
Likely power supply failure, especially with the bad smell
Sep 10, 2012 | Element Electronics FLX-3211B 32 in. LCD...
If the audio still works then the inverter would be the most likliest cause. You can get the inverter board from
Aug 12, 2012 | Element Electronics FLX-3211B 32 in. LCD...
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
32" Element HD LCD TV screen often sticks to one
The tv have a long board called a LCD inverter board it is dying.This LCD inverter board help the tv LCD screen panel to have a backlight for the tv LCD screen panel to produce a picture.Tries websites like, to buy a refurbish a new long LCD inverter board for the replacement.
Oct 09, 2011 | Element Electronics FLX-3211B 32 in. LCD...
I have a 32in element flat screen had for couple of months now tonight there is a black box in the middle of my screen what should i do
I would like to know the same. We purchased ours on 10/25 and on 12/29 a black half moon shape showed up in the lower left hand side of the screen. Now the rightmost side of the screen is almost covered in black circles. There are also varying widths of lines going up and down on the right half of the screen.
We have tried contacting cusomer service and keep getting voicemail.
Nov 05, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Element hdtv flx3210 shuts video off after a few seconds.
Send the set back for service.
The power supply most likely failed, or another circuit board has failed and the set is in the protect mode.
I would consider to see if the dealer would exchange the set for a well known quality brand name set and pay the difference.
Jerry G.
Jul 11, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
