Question about Cameras
I installed a micro SD in my left pan and in settings indicated to write to card as default. But the tablet does not write to it at all. Card is inserted correctly. Any advice?
Card is 32GB.
SOURCE: Micro SD card not read
The Sansa c250 and lower cannot read SDHC cards. They must be regular SD cards for the c250 to "see" them. That is, they must be of 2GB capacity or lower. If the card is 4GB or higher, it is a SDHC card and will not work.
Posted on Apr 02, 2009
SOURCE: Setting Micro SD card
Format the SD card before placing it into the slot. Even I had the same problem.
--Udai
Posted on Apr 26, 2009
SOURCE: PROBLEM WITH NOKIA 5300 EVERYTIME MICRO SD CARD INSERTED..
nokia 5300 card rider problem
Posted on Sep 21, 2009
SOURCE: why 32GB micro sd tf memory card only US$98.00?
I believe this company is located in China. Their website states that their products aren't brand name. My advice, buyer beware.
Posted on Sep 16, 2010
  • 7 Answers
SOURCE: cannot insert micro sd card in samsung c414
I found the micro card insertion to be a pain on this phone. If you're looking down at the top of the phone, the micro card goes into the phone with the bottom up (brass contacts facing upwards), then you will have to use your fingernail to get that ****** to lock in. Sometimes I get so frustrated that I use the tip of a pen or whatnot to get the card to lock in. I hope this helps, but it could be a technical issue with something wrong with the card loading slot.
Posted on Aug 27, 2012
Use of storage card
Gordon, Move the stuff on tablet to the SD card to free up space.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Move Android Apps to an SD Card
Galaxy Tab How do move photos videos and other files on my Samsung Galaxy...
internal storage full how to move to SD card
Aug 04, 2016 | Tablets & eReaders
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
GuruAid.com
Jul 22, 2016 | Polaroid 7-in. Internet Tablet - Other
How do I download apps onto this device?
The default on most tablets is to install apps to internal storage so the SD card does no good by itself. You can go into Settings>Applications and change the location for each app to the SD card. Likewise anything else you put on a tablet, particularly photos and videos get stored in internal storage. If you have taken a lot of photos and videos they can fill up your storage quickly. You can change this in the Camera app by tapping the settings icon and changing the storage option to SD card. You will still need to actually move existing photos and videos to the SD card manually or copy them to external storage and delete them. I would also change the image and video resolution in Camera settings to 640x480. This is plenty good enough for pictures you just want to look at on the device or share online.
Jan 04, 2016 | Trio Stealth G2 7 inch Tablet with 8GB...
It will not recognize any SDHC micro card I put in it.
you needto put 1 in and then go to settings an "mount sd card",for it to recognize it
May 07, 2015 | Tablets & eReaders
How do I get my micro sd card to work on my MiTraveler tablet
You will have to add an app at the play store. There are many, one that I have used is called send to card. Remember to turn off your device before removing your sd card.
https://play.google.com/store/apps/details?id=ru.gelin.android.sendtosd
Mar 10, 2015 | Tivax Tablet MITRAVELER7D4
How do i get my tablet to read my micro sd card?
Check to be sure the particular SD card is compatible.
Feb 04, 2015 | Nextbook Premium 7 Capacitive Touch...
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
