Question about Garden
Is there a blade timing for a 46 INCH 3 BLADE DECK
  • 49 Answers
SOURCE: craftsman snow blade install instructions
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Posted on Feb 06, 2009
  • 376 Answers
SOURCE: What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
Posted on May 17, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
nova2nv
  • 197 Answers
SOURCE: my john deere lt 133 mower with a double blade
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Posted on Nov 14, 2009
miket756
  • 2702 Answers
SOURCE: 42 inch jd la115, hit stump in yard, changed blade
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Posted on Aug 15, 2010
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
I NEED THE SIZE OF THE BLADES OFF A 46 INCH DECK THREE BLADE SYSTEM IT IS A POWER KRAFT LAWN TRACTOR I NEED THE SIZE OF THE LAWN MOWER BLADES
This is a part number.46 inch (three blade) 18 HP TMO 3400005A
MTD makes these mowers.You should be able to use those part numbers to purchase replacements.You can find online at the mtd web site,or Lowe`s and wal mart sell those,or at least some of those parts.
May 12, 2011 | Computers & Internet
982 cub cadet 3 blade w/ idler pulley deck belt diagram
hi there pauly 46 here
here is web site for streetsign cub cadet 982 46 " deck with 3 blades
http://www.partstree.com/parts/?lc=cub_cadet&mn=336+46%22+Mower+Super+Garden+Tractor&dn=0057000002
this shows deck belt routing
and here is website area for 982 parts break down for model 982 cub cadet
http://www.partstree.com/parts/?lc=cub_cadet&mn=982
take a look cheers hope it helps
pauly46
Apr 28, 2011 | Cub Cadet Street Sign- tractor lawn riding...
What size and how many blades do I need for my husqvarna 21 hp riding mower with a 46 inch deck?
Well I guess laying down next to it and taking a look under the mower deck is beyond the question. One could ask about how many teeth the horse has or just look in its mouth. However, I am going to guess 3 blades as 2 blade units usually are 42" cut maximum. Mine is 48" and has 3 blades.
Mar 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Need diagram to replace blade belt for 19hp twin turbo cool mower
You have to post the model number from under seat. Not all Craftsman decks are the same. There are 38", 42", 46" w/3 blades, 46" w/ 2 blades, 52", etc.. Better yet, Get the model number under the seat (starts with 917) and go to... http://www.searspartsdirect.com/partsdirect/index.action Then enter the model #, hit search, then scroll down to Browse Subcomponent List and click on Mower Deck. There's your diagram.
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
46 inch cub cadet mowing deck need diagram for belt
Go to... http://www.partstree.com/parts/ Click on the Cub Cadet logo then enter your model number. All the diagrams are there.
Jun 11, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Craftsman 917273223 50' cut. Hit a stump with right blade started cutting poorly on right side. Replaced blade still cut bad. Replaced a 3 blades and still cutts bad on right. Held pully and tried to turn...
you need to bring all 3 blades to point at each other on the deck
do they all look the same?
aLL 3 should meet each other evenly with no more than 1/8th inch difference high or low point to point.
the stump strike could have bent the deck on that side
also be sure the fin side of the blades are pointing towards the deck when installed.
check that your deck is level on a level surface and the air pressure in all for tires are up to recommended pressure.
most of the time 14psi front and 10psi rear
Jun 09, 2009 | Craftsman Garden
I need a belt diagram for my lawn mower>
If you don't have the model number, I just found a diagram for mine by Google, by typing in "MTD 46 inch deck diagram" It took me to a Parts Tree site and right to the diagram I needed. There are slight model differences but for years, the 46 inch, three blade deck has been essentially the same.
Apr 26, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
