Question about KitchenAid Kitchen Ranges
Kitchenaid double oven gas range KGRS505X keeps telling me to please make sure the stovetop knobs are in the off position then press start or off. The knobs are in the off position.
It started doing this here n there a couple mo. ago now does it a few times a day. The range is almost 3yrs old
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Posted on Jan 14, 2010
SOURCE: kitchenaid gas range model KGRS807S - oven starts then stops
earl am16 error
Posted on Apr 16, 2010
Daniel S
  • 4323 Answers
SOURCE: can't open oven door on my kitchenaid gas range.
Hi
This indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 08, 2011
dyronwebb
  • 220 Answers
SOURCE: I have a double oven kitchenaid natural gas range model KGRS505X. When I cook in the upper oven nothing I cook will brown. Buiscuits get cooked but are still ehite when done. What is the problem?
The top oven not maintaining heat why plenty of reasons depending on age could be a weak ignitor, bad temp sensor, is the oven light on if so oven stops heating after 30 seconds any oven maintaining set point temp will brown and if left long enough burn
Posted on Jan 27, 2015
Jan 26, 2015 | KitchenAid Kitchen Ranges
My oven tepteratures are not correct. They are at least 100 defree too hot?
Be sure thermocouple/temperature probe inside oven is clean of debris that may have been spilled on it. Be careful and gentle with it but you can get a piece of steel wool and wrap it around it and rub to clean it. Ok to rub end hard , just be careful not to kink thin tube going to it. Make sure it didn't get hit as well and is out of position. If that doesn't help, or no debris causing it. You may have an adjustment screw in center of oven control, behind the dial, simply pull dial off and look close down center of shaft for small slot for screwdriver. Turning it one way or other should change temperature. Please confirm make and model number and I can dig deeper if above info doesn't help. Keep me posted please.
Mar 08, 2014 | KitchenAid KGRS505XSS double oven...
Ignitors continue to pop altho all four knobs are in off position Kitchenaid gas stove top Model #KGCT305X Serial #XB2806974 ir X52606974
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 21, 2011 | Microwave Ovens
I have a kitchenaid gas stovetop range and the burners have stained and I'm trying to find a way to clean them. Would oven cleaner take off the stains on the metal burners?
Sorry to read about your problem, I hope this helps you out.
yes, you can heat them up just a little, or use the cold directions on the spray can..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | KitchenAid KGSK901SSS Gas Range
Kitchenaid Range KGRA806PSS Control Panel Not Functioning
You're right about not using the self clean option. Your oven gets up to over 800 degrees when you use that feature. You can choose to simply keep your oven wiped out, rather than self clean it. The timer is most likely going out if the "stop" button doesn't work after cleaning. Please call or email us and we will be sure toget the right part for you. I hope this solves your problem. Ella
Sep 09, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
HELP! Stovetop elements don't work and oven burner doesn't work
sounds silll but check your circuit breakers make sure both of the 2 breakers fedding this unit ar in the on positoin , itts possible youve tripped half your circuit.
Oct 21, 2008 | KitchenAid KESC307 Electric Kitchen Range
Gas stovetop not igniting without matches
If the rest of the surface igniters are working, more than likely your spark module is working fine. (This is normal, by the way) I would suspect that you have a bad spark electrode at the burner in question, a bad burner switch, or bad wiring.
I found several part listings for the model number you posted this question under at repairclinic.com. You will need to provide a more complete model number in order to narrow your search to ensure you get the right part. You can find your model number on a nameplate around the oven door opening, or lower drawer opening (if equipped). Some manufacturers also place this information on the back of the range.
I hope this helps answer some of your questions. Please reply back to this posting if you need further troubleshooting guidance.
May 14, 2008 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
