Question about Ariens Garden
How to replace drive belt on ariens max 60 in
2 Suggested Answers
  • 76 Answers
SOURCE: Do I have to split
No. If you have someone squeeze the auger handle, that will allow you to remove the belt. You'll need to do the same to put it back on. Make sure to put the belt on the bottom pulley and not over one of the belt guides otherwise you will end up replacing the new belt also.
Posted on Jan 12, 2009
Have an Ariens Max Zoom 60, when engage the mowing deck the engine loads up and RPM's drops way down" Have tightened and loosened belt, what else can I Try?
Something in the mower blade drive is binding up. That puts a drag on the engine and causes the slow down in RPM.
Jun 16, 2017 | Ariens Garden
Well my ariens platinum sno 24 inch which is 3 years old has a rotor jam this morning and some smoke came out of it so i turned it off. What can i do?
The smoke was probably from the drive belt. You have to clear the jam first, and you may also need to replace the drive belt.
Jan 01, 2017 | Ariens Garden
Having trouble removing drive belt
Remove belt from opposite end so you don't fight with clutch end.
Jul 02, 2015 | Ariens Max Zoom 60 in. 25 HP Kohler...
Why does the wheel Drive seems to slip / stop ?
no tension adjustments replace fluid and filter should improve
Jul 16, 2014 | Ariens Garden
How to relace drive belt on ariens tractor a20va46?
There are multiple belts on the Ariens A20VA46 lawn tractor. Which belt are you asking about?
Service and Owner's manuals can be downloaded from the following link: Find Manuals by entering your tractor's model and serial numbers.
The deck drive belt is easy to change by releasing spring pressure on the idler pulley (usually under a plastic cover). See the user's or service manual for directions from the above link.
The two transmission belts are somewhat more difficult, but are usually long-lasting. The newer type of continuously variable transmissions used on these tractors have a friction belt like a snowmobile but under much less load. As a result, they are long-lasting. The engine to transmission belt is a conventional V-belt and may require occasional replacement. Usually, there's a similar tensioner pulley you would release in order to replace this belt.
Jul 14, 2014 | Ariens 34 In. Zoom Series Riding Mower
How do you change hydraulic fulid on max zoom 60
you could take off the return line and insert into empty bucket then watch fluid go down in tank as it is pumping out then start adding new fluid till u think the old in the lines and drives is out then connec t hose and filler up. but y do u want to change it? did it get contaminated?
Apr 24, 2014 | Ariens Max Zoom 60 in 26 HP Kawasaki Zero...
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Where can i get an ARIENS drive belt, new or used
Anyplace that sells Ariens mowers will have one. Most other lawn mower stores can also sell you one. Remove the old belt and take that and the model Airens you have to get a replacement. You do not want a used belt just get a new one.
May 01, 2010 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
