Question about Microwave Ovens
I have a merh752bab range door broken handle. Want to replace HELP
MicrowaveSvc
  • 9098 Answers
SOURCE: Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Chances are the door panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption of nearby electronic devices. You can find exploded view diagrams and order parts here: http://tinyurl.com/gv383 We have critical safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Feb 06, 2007
MicrowaveSvc
  • 9098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
  • 718 Answers
SOURCE: Broken door handle on GE JVM1490 900 Watts
Go to ;
http://www.appliancepartspros.com/
and enter the model number etc of your unit. Note the diagrams in the left-hand corner of the screen. They also sell parts. Tools will be simple screwdrivers and small wrenches.
Posted on Mar 21, 2009
jsrock516
  • 5911 Answers
SOURCE: Microwave broken door handle.
To replace MOST microwave oven door handles all you have to do is open the door and remove the inner plastic panel around the glass. This is accomplished by taking a small screwdriver and carefully inserting it along the perimeter to pop it loose (there are usually some grooves you can insert the screwdriver in).
NOTE: DO NOT pry against the glass. The glass is tempered and has an RF shield that protects the consumer from the microwaves being generated by the magnetron. Breaking it, requires a new door replacement.
With the panel removed, you will be able to access the screws that hold the handle in place. Once the new handle is in place, carefully reinsert the inner plastic panel by snapping it back in place all the way around the perimeter of the door glass.
If you have questions, or if your door is configured differently, please let me know. If you have the ability to send photos, that helps too. A model number may also be useful so I can identify how your door is assembled. I hope this helps you,
Posted on Apr 23, 2009
jsrock516
  • 5911 Answers
SOURCE: Broken handle on over the range microwave
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. If the model number you have this question listed under is correct, the part number for a replacement handle is 5304440323.
If you have any questions, please post back with your complete model number (if different than the one listed) and let me know. I hope this helps you.
Posted on Apr 12, 2010
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
How do you take the door off? I too have a broken handle and door...
If only the door handle is broken, it can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle on this model has two parts (items 3 and 8). Depending on what is broken, you may only need to order one or the other. Both parts, combined, is still only about $20. The part numbers are WB15X10119 and WB15X10120, respectively.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The lower handle retainer is broke
If the model number is correct, this is a parts illustration of your oven door:
http://pcappliancerepair.com/model-display.php
If you have any questions, please post back with your and let me know. I hope this helps you
Jun 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE Profile spacemaker 2.0 handle is broken. How can I change it?
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you
May 31, 2010 | GE Profile Spacemaker Over-the-Range...
How do i replace a broken over the range micro wave door handle
The door handle is a simple repair that can be done with the door in place, or removed. And, you do not have to uninstall the oven if this is an over the range model.
It would help, however, to know what brand and model microwave oven you are referring to. All ovens are not designed the same and are assembled in different ways. What I have provided you with is the basic information that applies to most microwave ovens. If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you
Apr 24, 2010 | Microwave Ovens
Apr 12, 2010 | Frigidaire FMV156DC Microwave Oven
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
Kenmore mirowave # 72162643200 handle is broken
I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
As for the door... I very CAREFULLY used super glue/ gel and it did the job!
Mar 27, 2009 | Kenmore 62643 Microwave Oven
My magic chef over the range microwave oven handle is broken, i ordered the part online and have received the same. However I do no know how to remove the old broken handle and replace it with the new...
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 01, 2008 | Magic Chef Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
