Question about LG Televison & Video
Sound bar won't connect wirelessly to lg to ?
4 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: My ilive itp180b sound bar won't play sound from my lg plasma tv
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Posted on Apr 02, 2012
sethtorvea
  • 17 Answers
SOURCE: LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
Posted on May 08, 2014
mike0862
  • 5630 Answers
SOURCE: I have an LG 50LB580V led TV... And am trying to
To connect wirelessly to your soundbar the TV would have to have Bluetooth capability, I don't believe your TV is Bluetooth enabled!
Posted on Dec 28, 2014
Need instructions lg sound bar remote control akb74815321
  1. Turn on your Sound Bar.
  2. Select LG TV function by using FUNC on the remote control or F on the unit until the correct function is selected.
  3. Set up LG Sound Sync (Wireless) on the TV. Refer to your TV's instruction manual for detailed steps
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 11, 2016 | LG Televison & Video
How to connect sound bar to 2011 smart tv
If your soundbar has bluetooth technology in it, turn it to the input of "Bluetooth" or "BT". In your TV's smart menu, you should be able to find bluetooth settings, and be able to find the soundbar from there. If you are looking to connect it by a cable, you will have to connect a digital optical cable into the back of the TV, and run it down into the soundbar to receive sound out of it.
Feb 22, 2015 | LG NB3510A 2.1 Sound Bar with Subwoofer -...
Connect LG NB3520A to Fisher RS-625 receiver
You would have to install a speaker selection switch. You cannot directly hook up 2 amplifiers to one set of speakers without destroying one or both amplifiers. Unfortunately, one set of amplifiers is inside your sound bar. An external switch would have to be installed on your sound bar as well as speaker terminals that would connect to your Fisher.
If you have a line out or tape out on your Fisher, and you have an analog input on your sound bar, use could use that as an alternate solution. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | LG NB3520A 300W Sound Bar with Wireless...
Button standby
The receiver is in protect mode, most likely due to a damaged amplifier. This protect mode, keeps the unit from turning on and causing further damage to itself and/or your speaker system. For more information, please visit my website at audioserviceclinic.com. Thank you.
Jul 27, 2013 | LG Lsb316 Sound Bar With Wireless...
CANNOT GET SOUND FROM THE KLIPSCHE SOUND BAR CONNECTED TO AN LG TV
If the sound bar has optical connection I would hook up to tv that way. I had to do that with my lg and sound bar. Hope this helps. Good Luck.
Mar 27, 2013 | Klipsch Power Bar Soundbar with Wireless...
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Televison & Video Logo
29 people viewed this question
Computer Repairing
Computer Repairing
