How do I erase a Program C Only want to use Program A and Program B is Blank like I want it to be -------
Erase old videos
Ideally, you'll get a high-powered bulk tape eraser that is designed for video tapes and will work perfectly for audio tapes, as well. An audio tape eraser will work to a point, but usually won't blank them out completely since it doesn't put out a strong enough electromagnetic field to erase videotapes completely. I personally own an old Radio Shack high powered eraser and it works to erase both video and audio, as well as a demagnetizer for old color tv screens (when used at a distance...a bit too strong up close), and demagnetizing screwdrivers (the ones I don't want magnetized, that is). Hope that helps.
Apr 11, 2014 | Sony HI8-MP Hi-8 Tape
My computer will not recognize the mp3 player, so I cannot load any songs onto it, the worst part is i think i erased the program files by accident please help me ,
You will need to download the drivers to your computer so that it will recognize your mp3 player. Just google " drivers for _______" in the blank put the name and model of your player.
Apr 25, 2011 | Video Game Consoles & Games
I have kingston 64gb data traveller 101 its healthy but cannot be formatted due to blank system files and fat
I need to know what operating system you are using. Make sure you save your data first. You need to re-partition the stick to erase the previous format. Then you can format it. A different program is used depending on if you have XP, Vista, or system 7. just a a side note, WIN98 had the best partitioning program but Microsoft discontinued it. Go figure.
Nov 18, 2010 | Computers & Internet
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
I cannot add additional photos to my dvd-rw disc though I had burnt only one image on it.The pop-up notice always requests/asks to override the above to enable further recordings/ insert a blank disk. Your...
There is a chance that your program automatically closed the session on the disc. If it does this there is no further burning allowed. Your best bet is to copy the image from the disc onto the computer, then using your program erase your re-writable disc. When burning the images onto your disc be sure the option is not checked to close the disc.
Jan 08, 2010 | Computers & Internet
No matter what blank dvd i put after preparing it says INVALID DISK !!!help!!!
It may be dust in the connectors. If you remove the cover and use a can of dust remover to blow out any dust, also, blow out the connector holes. I fixed to VCR's like this. Good Luck.
Sep 05, 2009 | Dual Presidian DVD Recorder
Erasing the TDK microcassettes
use a bulk magnetic tape eraser from radio shack. the eraser head in your machine is mal-adjusted and, would be too difficult to fix
Jul 01, 2009 | TDK Microcassette 60 min Micro Cassette
System boots to a blank screen
Do this unit have the features to restore using a restore disc? If yes then you have to restore it using this. It will be back to a factory setting just like when it is new. All save files and added program will be erased and deleted.
Or if it have an options for repair choose that.
Try hitting Pause when system start up so that you can read the boot options.
If not then try to boot and choose the option REPAIR from your operating system installer disc.
May 24, 2009 | Dell Dimension C521 PC Desktop
CD is still blank after running the burn program
Go into your burner settings and uncheck the box that says erase or format disk before use.I had the same problem in Vista and that is what I had to do to fix it.
Jan 07, 2009 | Gateway (5502216) CD-RW/DVD-ROM (Combo)...
Video8 to DVD
First erase the DVD and then try...
you can erase DVD by right clicking the drive in my computer and selecting "ERASE DVDRW"
then you try to write onto the DVD-RW
Apr 11, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
