Question about Bissell Vacuums
I need an instruction manual for a bissell proheat 2x 12amp! Could u send me one please?
cheebster
  • 39 Answers
SOURCE: manual
Hi vanessaking. Here is a copy of the user's manual for it; http://www.bissell.com/images/UserGuides/9200-605web.pdf You might also wanna take a loot at this support section for this specific model for any other concern; http://www.bissell.com/Products/product.asp?catalog%5Fname=Bissell&category%5Fname=&product%5Fid=ProHeat+2X Hope that helps ! :) cheebster.
Posted on Jun 18, 2007
  • 389 Answers
SOURCE: How do you operate the Bissell 1725 LittleGreen Machine Proheat
Go to www.bissell.com then click the Customer Service tab. In the next window click on the User Guides link (in green on left hand side), then enter your model number. You can then download the full instructions.
Posted on Mar 15, 2009
  • 29 Answers
SOURCE: Bissell Proheat 2x Not Putting
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix. My Bissell model is different than yours, but many are similar.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Posted on May 29, 2009
SOURCE: Repair manual for Bissell 2X ProHeat 9200 Carpet cleaner
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000074560.pdf
Bissell Manual
Posted on Feb 24, 2010
SOURCE: my bissell proheat 12amp is not spraying water
When I desided to purchase a Bissell Deep Cleaner I read up on everything on the Bissell, even the problems people where haveing with them. I bought the Pro heat select 2X deep cleaner and I take very good care of it, cleaning everything through with warm-hot water 3-4 times over to get all of the cleaning solution out of all of the lines as well as the tools, the solution "will" biuld up in the lines! Seeing how clean my carpets maybe every 3-6 months, i take this time to clean because the machine is not cheap! I also have to take off the brush heads and clean the and the area as well because i have pets and i get alot of hair build up!
I just set up my Bissell to use, and no spray! for me in was the spray heads under the water contianer, lift off the contianer like you need to dump out the old water and add fresh hot water, as you lift you will see the two (mine are red) red colored spray heads that are "snapped" into place on either side, they have little clips over the heads that can be "pressed together" so you can release the spray head, now this will not be easy because the heads are in there good but they will come out and a little tuff putting back in! But that was my problem, there was calcium a such, build-up in the spray head and more just sitting in the line. I cleaned the spray head with a "skewer", yes a BBQ "bamboo" meat skewer was the perfect size for the hole in the spray head. Then i got a container an took the open ends of the spray line and directed them, one by one into the container and I turned on the machine and pressed the spray button and bits and pieces came flying out! problem solved! I hope I have helps some of you!
I know it's a pain, but you have to clean out the machine very well after your done!
Sorry, but i'm not going to proof read! Lol, take care!
Posted on Jun 09, 2010
Instructions needed
Please see the owners manual link to your Bissell ProHeat Cleaner below:
Bissell ProHeat 2X CleanShot Owners Manual
Hopefully this helped you,
Chris JonesGoVacuum
Oct 01, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I just need operating instructions.
I believe you will find what you are looking for at this URL:
http://safemanuals.com/user-guide-instructions-owner-manual/BISSELL/PROHEAT-2X-CLEANSHOT-9500-_M
Sep 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x manual
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 16, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do you change belt on Bissell pro heat carpet cleaner. can you please send diagram or instruction how to change belts.
http://www.bissell.com/images/UserGuides/7950_1204.indd.pdf
here is the complete manual (it is in pdf form)includes diagrams & instructions on belt replacment.thanx for using fix-ya!!!please rate all replys.
Nov 30, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
No Manual
I need a manual for the bissell proheat 2x 9200 carpet cleaner.
Nov 17, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Lost manual for bissell pro2X rug cleaner can I get inst. on line?
hi,
Just recently purchased proheat 2x rug cleaner ,miss placed my manual and can't get the water sucked up . Please Help
Thanks
Jun 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Proheat 2x "catches" when it is pushed forward-- Help Please!!!!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=499675
Bissell ProHeat 2x "catches" when it is pushed...
Posted by Marlene101 on Apr 08, 2008
My ProHeat 2x bucks and catches when I try to push it forward-help!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Bissell 9500 ProHeat 2X Clean Shot Upright
The Bissell is not designed to be like a vacuum – it is designed to clean on the pull back, you dispense the Bissell cleaning fluid, the brushes scrub the carpet and the suction will vacuum up the excess water, the push forward will do the reverse action. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
32 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
