How do I erase a program "C" Only want to use program "A" Program "B" is blank like I want it to be
2 Suggested Answers
  • 11800 Answers
SOURCE: ERASER PROGRAM Looking for a free program that
Try this one
http://www.softpedia.com/get/PORTABLE-SOFTWARE/System/Backup-and-Recovery/Portable-Recuva.shtml
or this one
http://www.softpedia.com/get/Security/Secure-cleaning/Universal-Shredder.shtml
Posted on Nov 05, 2010
Forgot password and how to unlock
If this is a windows computer, you can look online for a program to erase your current windows password. I found one called Offline Windows Password & Registry Editor. I had to
1. download the program onto a second computer that I could logon to,
2. Burn the program to a DVD or USB stick
3. Go back to the computer I forgot my password on, and turn it off/on
4. As it is turning on, press the F?? key that the screen says to go to the boot menu.
5. Tell your computer to boot to the DVD or USB stick
6. Follow the instructions included with the software to reset your password to blank. Note: Remember what account you login with, so you reset only that account's password.
7. You should be able to reboot your computer, and login without a password.
May 07, 2015 | HP Pavilion dv4000 Notebook
Unistall windows 8 pro
You have to install another operating system
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
or
Formatting a hard drive to erase its contents does not mean the files are necessarily gone forever. Using data-recovery software, someone still could retrieve sensitive data and files from your hard drive even after you've formatted it. Instead of simply formatting your hard drive, use disc-cleaning software to permanently erase its contents. Disc-cleaning programs work by repeatedly overwriting the contents of a hard drive with random data patterns, making it virtually impossible to recover the original files. Download and install the freeware program Active@ KillDisk (see Below). http://www.killdisk.com/downloadfree.htm Click the Windows "Start" button and select KillDisk from the "All Programs" list. Click the check box next to the hard drive you want to erase in the "System Local Disks" menu. Press the "Kill" button. Select the erasing method you want to use from the "Erase Method" drop-down menu. Active@ recommends using the "US DoD 5220.22-M" method. Click "Start" to begin erasing the hard drive. Download and install the freeware program Hard Drive Eraser (see Below). http://www.harddriveeraser.org/ Click the Windows "Start" button and select Hard Drive Eraser from the "All Programs" list. Check the radio button next to the hard drive you want to erase under "Select Drive to Erase." Select the erasing method you want to use from the "Shredding Scheme" drop-down menu. The developers of Hard Drive Eraser recommend "DoD 5220-22 M" Press the "Start" button to begin erasing the hard drive. Download and install Iolo DriverScrubber (see Below). Click the "Windows" Start button, "All http://www.iolo.com/ds/3/ Programs" and then the DriverScrubber program icon. Click "Wipe all contents of a drive," and then click "3.5-Inch Floppy Disk." Insert a blank floppy disk and click "Next." Restart your computer with the floppy disk still inserted. Your computer will boot directly to DriveScrubber. Press the down arrow on your keyboard to highlight the hard drive you want to format in the "Available Physical Drives" menu. Press the space bar to select the hard drive. Press "Enter" to continue. Press the down arrow to highlight "Seven Overwrites" in the "Available Data Wiping Methods" menu, and then press the space bar to select it. Press "Enter" to continue. Press "CTRL," "ALT," "Shift" and "W" at the same time to wipe the hard drive. Hope this helps.
b>
Dec 30, 2012 | Dell Computers & Internet
I am having trouble turning my mp3 disney pix
that is a program failure.reinstalling the program will correct the problem
check also the song capacity of the memory erase some files to lessen the load
erase also corrupted program this will cause the system to hang..
Jan 24, 2011 | Disney Tink Digital Mix Stick MP3 Player...
How do I delete program times for the filter pump on the Aqualink rs8 panel?
These are great systems: Go into "MENU" (MENU BUTTON) Scroll down until you see "MENU/HELP" Scroll down to "PROGRAMS" - HIT "SELECT" when you find "PROGRAMS" It will say "PROGRAM 1 of 1" that is what you want - Hit enter - This will tell you what time the program is set to run
If there is more than one program, You will see "PROGRAM 1 of 2" or however many programs you have programmed.
If you need to delete a program, go to the program you are looking to delete, it will ask you if you wish to delete the program and you will use the up and down arrow on the panel.
It is really that simpe!
For deletion of all programs (factory default). There is a SMALL reset button. The lights will go out and then light up. Will light up to the left and then to the right. Resetting this will erase all run times back to factory default. You will not loose your programs (memory of knowing what system it is) it just resets the times to factory default (1200 Military times). ***IF YOU HAVE A COMPLICATED PLUMBING SYSTEM WITH SEVERAL RUN TIMES - DO NOT DO THIS!**
If you are looking to just erase additional run times and only need the one run time (for circulation) this might be the better option to resetting and erase all run times and reset back to a basic 1 of 1 run time.
Dec 07, 2010 | Jandy Pool & Spa
I have kingston 64gb data traveller 101 its healthy but cannot be formatted due to blank system files and fat
I need to know what operating system you are using. Make sure you save your data first. You need to re-partition the stick to erase the previous format. Then you can format it. A different program is used depending on if you have XP, Vista, or system 7. just a a side note, WIN98 had the best partitioning program but Microsoft discontinued it. Go figure.
Nov 18, 2010 | Computers & Internet
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
No matter what blank dvd i put after preparing it says INVALID DISK !!!help!!!
It may be dust in the connectors. If you remove the cover and use a can of dust remover to blow out any dust, also, blow out the connector holes. I fixed to VCR's like this. Good Luck.
Sep 05, 2009 | Dual Presidian DVD Recorder
After i format my Creative Zen Neeon
After i format my 'Creative Zen Neeon', the program file seem to have been erased and i cant play songss with it anymore.HOW? help me! anyone can send me information and the program files for the MP3?
Jul 08, 2009 | Creative Labs Zen MicroPhoto MP3 Player
How to retrive erased images in Olympus Fe-20 degital camera
As long as the xD card was not formatted it is possible to recover the images that were accidently erased. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost or erased images.
Mar 26, 2009 | Olympus FE-210 Digital Camera
CD is still blank after running the burn program
Go into your burner settings and uncheck the box that says erase or format disk before use.I had the same problem in Vista and that is what I had to do to fix it.
Jan 07, 2009 | Gateway (5502216) CD-RW/DVD-ROM (Combo)...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
