I have a Logik washing machine and it is showing e52. Can you tell me what this means?
    Master:
  • 238 Answers
Hello!
Most likely, the error E 52 means that there is no contact between the tachogenerator and the electronic controller.
Posted on May 15, 2017
My washing machine has a code e21 what do that mean
Please read description carefully about error code
Logik Washing Machine Error 21: "E21"
Error Code Definition: Washer has not drained in allotted / time washer not draining.
How To Clear Error Code:
-Check that filter is not blocked or kinked
-Check drain hose is clear of any blockage or kinked
-Check wires to drain pump
-Check drain pump is not faulty
-Check level sensor and switch
-Check wires to level sensor
here is link for more about your all error code which will may helpful in future, LOGIK Washing Machine Error Codes How To Clear
here is video which helpful regarding solve and understanding error.
Mar 16, 2017 | Washing Machines
Error code E52 E91 F30 F48
Apart from the error codes you have not said anything regarding the machine or what is happening to it, use this link to find out different error code meanings for different machines
http://www.selfix-uk.co.uk/search-keyword.php
Regards Casper
www.selfix-uk.co.uk Domestic Appliance Help
Feb 10, 2017 | Washing Machines
MY LOGIK WASHING MACHINE MODEL L612WMS13 SHOWS ERROR 12, THE POWER WENT OUT WHEN THE MACHINE WAS STILL WASHING AND WHEN IT CAME ON IT DIDN T CONTINUE THE CYCLE AND THERE IS STILL WATER INSIDE
Remove the wall plug which _should_ reset the main board. If that doesn't work, you have to manually drain it by unclipping the drain hose and lowering it into a bucket.
Error 12 (E12)
Washing machine has detected an overfill situation This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
  • Check for overfoaming or over soaping
  • Check the air chamber and the pressure switch hose
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3848-logik-washing-machine-error-codes
Jan 20, 2016 | Washing Machines
Need manual for logik washing machine l712 wm13
Below is the only site I have found offering a manual. I have no experience with the site listed. You might look for WOT scores (Web of Trust), or reviews of the site.
http://manualpub.com/doc/logik-l712wm13-manual
Mar 04, 2015 | Washing Machines
HI would you what know what error code Er13 is?? on a Logik L614WD13 washer dryer?
Feature : Error Code-control panel display "Er13"
  • Answer : Reason:Drying heater element error. Sometimes caused by to much load during the drying cycle. Washer dryers can only dry half the wash load.
Nov 03, 2014 | Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
Why is my logik washing machine showing e21
Find the error code reference in your owners manual or check on the companies web site to determine the meaning of the error code and then try to fix .
Jun 29, 2014 | Frigidaire ATF6000ES Front Load Washer
Logik L712WM13 error e30
On a Logik L712WM13 E30 means there is something stuck in the door.
Feb 21, 2014 | Washing Machines
Got a logik washing machine error code e4. what the problem thanks
My washing machine in a logik and is displaying a E4 error code any now what's wrong wiv it
Jan 13, 2012 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
