I put together a new pc using an EliteGroup A780GM-A board, AMD Athlon X2 Dual-Core 7550 processor (with ARCTIC COOLING Freezer 64 Pro 92mm CPU Cooler), 2 ea Corsair XMS2 2gb DDR2, WD3200AAJS 320gb HD (SATA)& Sony Optiarc24X DVD/CD RW (SATA) into a Smilodon case with a 500W power supply. The PC powers up, but monitor stays blank. Notes: (1) monitor tests good on another machine); (2) CPU fan is running. (so I know there is power to the board). Ideas? ps: I have very limited test equipment.
    Sergeant:
  • 233 Answers
The problem with building your own pc there are so many things that can go wrong. Aging post and no doubt you have already found the problem.
Just in case others are so inclined to "Build their Own".
1. You CAN NOT load drivers without a monitor.
To ask have you loaded the Mother boards drivers from the CD is ridiculous. Since you stated the monitor is blank.
2. Check all cable connections. Many a loose IDE or Sata cable has caused me no end of grief.
3. Check the ram. Do not care if it is brand new. Check it!
Good test is to swap the ram if you have two sticks. MAKE CERTAIN they are seated and in the manuals specified slots.
4. Crazy but this happened once to me. Leave the monitor OFF and let the machine boot up. Once you KNOW the operating system has loaded. Turn on the Monitor and hopefully it will work. If it does, load the monitor drivers from the floppy or CD. You may have to down load them.
5. Is the power supply large enough to handle what you have built?
Building your own system can be fun and a learning experience.
When everything works. When it does not..... Bigger hammer? :)
Just kidding.
Posted on Oct 03, 2009
  • Computers & ... Master
  • 5,660 Answers
Did you install the CD disk that comes with the motherboard? It's the motherboard DRIVER'S disk.
Posted on Jul 25, 2009
Can MSI MS-6380E support radeon x1800?
http://www.legendmicro.com/store/2940_MSI-MS-6380E-010-KT3-Ultra-Socket-A-Socket-462-for-AMD-Athlon-XPDuron-Processor.lmsp
1) Motherboard uses a Socket A processor socket. Also known as Socket 462.
http://en.wikipedia.org/wiki/Socket_A
When they switched from the Athlon single-core processors, to the Athlon 64-bit dual-core processors, they went to a completely different processor socket.
AM2,
http://en.wikipedia.org/wiki/Socket_AM2
So using the MSI MS-6380E motherboard with a dual core AMD processor = NO.
I don't seem to find an AMD Athlon 64 X2 1.8GigaHertz processor, except for a mobile version. One used for a laptop in otherwords,
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113047
Uses a Socket S1 mobile processor socket,
http://en.wikipedia.org/wiki/Socket_S1
List of AMD Athlon 64 microprocessors,
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors
Pretend like I'm from Missouri, and Show Me.
Find the processor by it's AMD part number, and post the URL of the website in a Comment.
http://www.amazon.com/AMD-Athlon-Venice-Single-Core-Processor/dp/B003RXLMCC
AMD Athlon 64 3000+
SINGLE-core processor, not X2.
(Socket 939 processor socket, too)
Show me the Processor, and then we can go on.
Regards,
joecoolvette
Sep 11, 2012 | MSI Computers & Internet
How Do I unlock CPU cores with Bios on MCP61M-M3 motherboard?
The motherboard supports AMD socket AM2 single-core Athlon 64/ Sempron and dual-core Athlon 64 X2/ Athlon 64 FX processors with 2MB / 1MB / 512KB L2 cache, which is based on 64-bit architecture. It features 2000 / 1600 MT/s Hyper Transport Bus, dual-channel un-buffered DDR2 800 memory support and AMD Cool 'n' Quiet! Technology.
The BIOS changes it on it's own when add a dual core.
Here is the PDF file on this board. Chapter 2 explains the Bios.
Jul 03, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
Hello again, Upgrading CPU's
Your board supports socket AM2 CPUs the fastest of which is the AMD Athlon 64 X2 6000+ dual-core processor at 3.1 GHz.
Your motherboard does not accept socket AM3 CPUs.
Dec 15, 2009 | Computers & Internet
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
Intel Pentium Dual Core and AMD Athlon 64 X2 processors
I'd advise don't start thinking below E2180. As per the performance go, E2180 and AMD Athlon 64 X2 5000+ are almost same but E2180 runs cooler. If you are going to use dedicated graphics card, go for E2180 and if you want a CPU for Integrated Graphics go for AMD Athlon 64 X2 5000+ because most of the 780G/790X chip-based AMD-compatible boards offer superior IGP.
Best wishes...
Nov 04, 2008 | Computers & Internet
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
