Question about Garden
I broke my drive belt on my Gravely ZT 48. Which belt do I buy to replace it?
  • 108 Answers
SOURCE: the belt broke while driving, if i replace myself
You should be able to do it with commom hand tools. But it would be wise to purchase a repair manual like Haynes or Chiltons specific to your vehicle and read over the procedure before attempting it to see if you want to tackle the job yourself. Also keep in mind that if your vehicle jumped timing there's a possibility that you could have bent valves. The only way to know this is by either removing the head (last choice) or putting the new timing belt on and checking for compression or simply trying to start it. You will also need a floor jack to support the engine because you will have to remove the mount on the side your timing belt is on to replace it. So to do it yourself you will need: 1)a repair manual for reference and it will also show you how to line up your timing marks, 2) good set of hand tools, 3) floor jack and block of wood (to place on the jack to protect the oil pan while you use it to support the engine), 4) patience, especially if you've never done one before it also wouldn't hurt to have someone who has done a few timing belts to at least be handy if you need a second set of eyes or hands. Because if you get the timing wrong the car won't start and there's always the possibility of internal damage. Once you've replaced it and you try to start the car if it doesn't start double check your timing marks, if they're good, then do a compression check of each cylinder if you have low compression then you have no choice but to remove the cylinder head and have any damaged valves replaced. Hope that helps, gl.
Posted on Nov 20, 2009
  • 15 Answers
SOURCE: How do you replace the belt. It broke and I see
You may find a manual at the Husqvarna website.
Posted on Apr 19, 2010
  • 3506 Answers
SOURCE: i replaced the electric clutch switch etc on the
It sounds like you have made an error in wiring it
Posted on Nov 24, 2014
  • 3506 Answers
SOURCE: its a gravely zt 2250 new electric pto switch and
If the blades are PTO activated then you have wired the pto incorrectly
  • 1917 Answers
SOURCE: ok so the problem,on my gravely zt 2250 is was
check the pto switchmake sure electric is shutting off
Posted on Nov 26, 2014
Ok so the problem,on my gravely zt 2250 is was mowing went to shut blades off and they kept on spinning and there also spinning when trying start engine replaced clutch twice still same problem
Sound like either the PTO relay is struck in run position or the PTO switch has failed and applying 12v to the PTO relay even in the off position.
IPLs for the Gravely ZT2250
Nov 24, 2014 | Garden
How do i replace the drive belt on a gravely zt 48xl?
I am not able to find a manual for the zt48 but looking at one for ZT50 should be similar. Refer page 29 for belt replacement after download from the link provided below.
If this is not same as your model then please post the serial number of your mover in the comments field.
Sep 23, 2014 | Garden
How do I put a replacement belt on a gravely promaster 200?
Any Gravely or Ariens dealer can help you with this... If you have your model number and serial number you can order it online
Sep 11, 2014 | Garden
How to tighten belts on a gravely zt 60HD zero turn lawn mower
Todays belts are not as good as the ones we once bought and tend to stretch out quickly and easily. More than likely you need to replace them.
Aug 23, 2014 | Garden
Gravely only clicks wont start but hour meter works
Sounds like a low battery, enough juice for the hour meter but not for the starter
Aug 14, 2014 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Feb 28, 2009 | Magic Chef CAV2004A Top Load Washer
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
