Question about Sewing Machines
Bernini 2000d won't respond to foot pedal. Won't sew
  • 323 Answers
SOURCE: foot pedal assembly for White sewing machine
You only need to replace the cord if it has been damaged. It will cost less if you just take the machine , cord and control to a local technician and have him just replace the foot control. Let him test it first. A generic foot control should cost less than $30.
sewman7
Posted on Dec 29, 2008
  • 1116 Answers
SOURCE: foot pedal doesn't work
You may need a new foot pedal. Find a small applicance repair shop and ask them if they can test the pedal. Take the machine with you.
Posted on Mar 09, 2010
SOURCE: My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Posted on Mar 24, 2010
Tally Girl
  • 1133 Answers
SOURCE: I have a Kenmore sewing
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
Posted on Jun 12, 2011
  • 980 Answers
SOURCE: Singer Golden Touch & Sew
Try a new needle first failing that you may need to retime the machine, you can email me for an attachment of instructions kendourof@yahoo.com
Posted on Aug 27, 2011
My faithful Bernini 801, foot pedal will not respond. It had been hesitating prior to this. It has been replaced once already......
Most likely your machine has carbon brushes that are worn and need to be replaced. (intermittent start-stop is a strong indicator. Not sure on your 801, but a lot of the older Berninas have carbon brushes in the motor (I've replaced them on an 830), Newer models have them in the foot control. Once you locate them, you can order replacements for probably less than $20 and your machine will run like a champ! There are web sites and videos that have instructions.
sewing machine carbon Google Search
Jan 30, 2018 | Sewing Machines
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
Mar 05, 2018 | Singer 7467S Confidence Stylist Electric...
How use mini sewing machine sb08
Search for:
Make Model manual
Dec 30, 2012 | Sunbeam Sewing Machines
Pfaff 1222se runs continuously,like I have the foot pedal down all the way. It won't stop.
sounds like there is a short in the wiring somewhere and the
machine needs to be serviced to find the problem
Dec 23, 2012 | PfaFF Creative 7570
The foot pedal makes noise, but won't turn bobbin.
only having the machine check at a sewing machine repair shop can say for sure
Mar 26, 2012 | Kenmore Sewing Machines
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
I have a Singer Sewing Machine #9444. There is no electrical getting to my machine since the light doesn't work and the foot pedal doesn't work after I turn on the machine
Try replacing the light bulb or rerouting the wire so it won't be affected by the light bulb or the foot pedle. Becarefull though because if you rerout the the wireing in the foot pedle you're taking away the off/on swich so it'll stay on. You may want to open up the foot pedle and see if there is anything loose, not conected or broken. The pedal is used as an on/off swich so it may just be stuck in the off position and not making contact when you press down on it so it won't turn on.
If you can't fined a blulb for it by the way you can disconect the socket where you screw it in and install a new one. Make sure the new one will fit in the same hole though. Then it should be easy finding a bulb for it. PLEASE MAKE SURE THE MACHINE IS DISCONECTED BEFOR YOU DO ANY OF THESE THINGS. Good luck!
Sep 30, 2011 | Sewing Machines
I was free motion quilting, machine stopped. Beeps three times when I push foot pedal and won't sew
Check your buttonhole lever, left back of the machine. Pull it down and push it right up into the machine. Should solve your problem
Sep 06, 2011 | Singer Confidence 7467 Mechanical Sewing...
When pressing the foot control the machine won't run, it shows the presser foot blinking on the screen even when the presser foot lever is down.
check the connections, if they are good, your foot pedal has a short in it, so its not completing the circuit when depressed
Jul 15, 2011 | Husqvarna Rose
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
