Question about Bush Televison & Video
Will a psu board from a 32inch tv fit a 40inch tv. It is a Vestel 17IPS19-5 V.1 061112. Mine is a Bush 40inch smart tv. Any help would be appreciated. Many Thanks
SOURCE: bush lcd tv
yellow screen
Posted on Apr 23, 2008
SOURCE: Bush IDLCDTV32TV22HD parts supply
hi can you said me if you can have the v32BC3 and the lvds cable?? where you have?I have the same problem and i search the same item. thank you .Freddy
Posted on Jun 28, 2009
Warf135
  • 137 Answers
SOURCE: I have Toshiba 15
There are a few things that can cause this fault, but the most common is the High Voltage Capacitors that feed the backlights going bad. The invertor and power supply are on the same board (Vestel 17IPS01-2)
The caps are on the power supply board and are C355 & C356 (12pf 3kv) and C354 (4.7pf 3kv). If you replace these caps it will solve the problem in 99% of cases.
If replacing these three caps do not solve the problem then it may be easier to replace the power supply board... as fixing means replacing a tiny surface mount chip with loads of legs.
WARNING: The Power Supply/Invertor board can contain LETHAL VOLTAGES even when turned off and unplugged. if you are not sure, Pay someone to do it for you!
Posted on Jan 26, 2011
gopakumarg43
  • 74887 Answers
SOURCE: bush 32inch tv has the power light on but has a black screen help?
Power light is there, and sound is OK, indicates the faut is with the horizontal output section. Check all the components in the horizontal output circuit. Line output transormer should be suspected.
Image of the suspected components attached.
Posted on May 09, 2012
mikadot
  • 2113 Answers
SOURCE: its not working for me plz help. Bush 40inch smart
Did you ever get the remote control wet? If so it can be taken apart and cleaned of any sugary contamination with water, a drop of soap and a toothbrush... dry and then put back together. If it is imperfect crazy glue foil to the bad buttons
Posted on Oct 21, 2013
How to flash bush[vestel] bios chip
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 14, 2015 | Bush 5693D 24" TV
My 32inch bush smart tv keep turning its self on and off how can I stop this
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 02, 2015 | Bush Televison & Video
Its not working for me plz help. Bush 40inch smart tv remote is not working
Oct 21, 2013 | Televison & Video
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
I have Toshiba 15" lcd tv with vestel 17ips01-2 psu/inverter board.the tv will show a picture for a couple of seconds and then the inverter cuts out.
Aug 13, 2009 | RCA Mikomi 5290925 15 in. LCD TV
Sep 04, 2008 | Televison & Video
Wharfedale lcd2010a
The TV is Manufactured by a company called Vestel in Turkey and will operate on the AK45 chassis remote control,if you try the codes for Bush or Alba one will operate it nut not of course menu functions but no problem there is a menu button on the side of the set.
audiovservices@fsmail.net
Apr 18, 2008 | Televison & Video
Televison & Video Logo
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
