Question about Individual Computers & Internet
My sprinkler system will not run when I push the on button. I can however run individual stations by using the manual button but that only runs one station at a time. I want all the stations to run.
It won't run automatically either. I tried resetting it by removing battery and Ac.
    Habit-Forming:
  • 154 Answers
Any time you remove battery or unplug both at the same time your system will need to be reprogram. the "on" button just turns system on you need to turn your function button to what you want to do... in your case just use the "test" button it will turn on all zones one at a time.
Posted on May 14, 2017
mydogisk
  • 50 Answers
SOURCE: Solenoid on one station, sprinklers on another, cant turn both on
the should be a pump or master solenoid connection inside the controller
Posted on Apr 13, 2009
SOURCE: my thinkpad is frozen in the docking station. to
I found the user manual over the internet and it told me where the emergency release is.
Posted on Nov 12, 2009
SOURCE: I have a Orbit 57161
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
SOURCE: black and decker air station won 't work
My Air Station blew a fuse also. The fuse that came with the inflator may be a bit too small amperage wise so I stepped up to .25 Amps more which is just a very small increase.
It is really ill advise to solder a wire in the place of a fuse. You are just asking for it.
The way I did it is I went to my local Radio Shack and got a small fuse holder with red leads and 1.5 Amp fuses. I soldered the fuse holder in place with the new fuse. And now I don't have to deal with any more solder. Just twist the fuse holder, take out the burnt out fuse and replace it with a new one. And wahlah. I'm back in business again.
Posted on Dec 18, 2010
SOURCE: How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
Posted on Feb 04, 2011
Display pulsates...doesn't allow me to run Manually - when I push Manual read out displays OFF...doesn't sequence to next station
Unplug it and take out the battery for a minute to see if it resets. If it does not, you need to replace it.
Apr 18, 2015 | Irritrol RD600-INT-R Rain Dial 6 Station...
How can the orbit mdoel 57894 be progrmed for multiple start times?
The product manual is confusing... how do you set 1-5 am and 2-12 pm and 3-5 pm? The manual says to press program button to choose A B or C programs, but does not give steps for programming or when to press enter to confirm setting... or say which position the dial should be in when programming.
57894 lets you program separately for each station...turn dial to Run Time and use arrow keys to select a station. Press enter or arrow keys to advance to next station.
57894 offers 'select a station', 'pick days of the week or interval between watering for that station', 'duration of watering for that station'. But picking days of the week is not the same as setting exact times 1-5 am and 2-12 pm.
The dial is set to auto for programs to operate..
Don't forget to activate battery located top right on face of timer.
http://waterheatertimer.org/pdf/Orbit-57894.pdf
So the 57894 has more options than a 24-hour analog sprinkler timer that repeats same cycle each day with 14-day-skipper.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Mar 12, 2015 | Orbit Hardware & Accessories
How stop sprinklers from starting over
You only program the first zone to turn on at a specific time. The rest of the zones go in sequence.
Aug 22, 2014 | Orbit 6 Station Indoor Dual Program...
Rainbird troubleshooting
Check to see if the wiring is crossed.
Jul 18, 2014 | Rainbird Rain Bird Esp-lx 4-station...
Use a straightened paper clip inserted into the hole. Push to reset.
Jun 29, 2014 | Garden
Charged my RD 600 system and water comes out of all 5 stations
Make sure the bleeders are closed. Sounds like all the valves are open and all are running at the same time.
Apr 11, 2014 | Irritrol RD600-INT-R Rain Dial 6 Station...
Battery won t charge
Turn off the laptop. Remove the battery. Leave the AC adapter attached. Power on the laptop to see if it runs on AC power alone. If not, then the problem may lie with the ThinkPad or the AC adapter.
Apr 23, 2013 | Lenovo ThinkPad Computers & Internet
Toshiba Satellite won't start up when AC plugged in
Try another Cord/Charger to verify the Cord, AC jack. If you plug in the AC cord after starting on battery, does the battery charge? Open Control Panel, Power Options, set to High Performance, Advanced power settings, set Sleep and Hibernate to Never, Adjust Advanced power setting to your preference.
Feb 06, 2013 | Toshiba Satellite L300D-ST3501 Notebook
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Computers & Internet Logo
Top Individual Computers & Internet Experts
john smith
gary433
k24674
Are you an Individual Computer and Internet Expert? Answer questions, earn points and help others
