Question about Tablets & eReaders
When i go update my linx 8 tablet its wont connect to the internet it tells me i have no drivers so i have to keep resetting it
3 Suggested Answers
  • 18 Answers
SOURCE: my new zte v9 wont connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
Posted on Dec 03, 2012
  • 708 Answers
SOURCE: Tro stealth g2 10.1 internet tablet - Andriod
Go to settings and make sure wifi is selected.
Posted on Nov 08, 2014
I don't know how to update yo iOS 8.0
To update you will need:
1 iOS tablet (iPad, etc)
1 wifi internet connection
1 power source
1. power on your tablet device.
2. connect to the wifi internet connection.
A. Open settings
B. Open general
C. Select "software update"
You should now see what update is available. If you are below iOS 7, you will need to update to version 7 to be able to see iOS 8 as available on some devices.
3. Locate iOS 8.x.x (on my tablet it is 8.1.3 as I wrote this)
Make sure your tablet is plugged into a power source (you don't want it to lose power while updating)
4. Under the iOS update you want to install, select "install now" "download now" or "download and install"
5. Select "agree" when presented with the terms and conditions
You should see your device "downloading update" or "verifying update"
I have seen occasions where it will download but will not install until the process is repeated. (On one device I had to "install now" 3 times because the update failed to download or failed to install.
Feb 01, 2015 | Tablets & eReaders
My Linx 7 tablet keeps dying even if I;m not using it. Constantly needs to charge can I change the settings to stop this
Are you actually turning the tablet off when you are not using it? (Hold down power button until Power Off box appears on screen)? If not, your tablet is constantly using power even with the screen blanked and will drain the battery. You could have a bad battery that is no longer holding its charge. How long can you run the device off the charger continuously? That length of time might indicate the state of the battery. Check the manual for expected battery life, which for a Linx 7 is usually 4 hours or less.
Jan 19, 2015 | HP Tablets & eReaders
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Need to download iOS 8.0.1 on my apple ipad keeps telling me it failed because I am not o internet, but I know that I am connected to the iternet what is wrong?
if you have laptop/desktop computer you can sync the iPad with iTunes and download iOS 8.1.2 there:
Upgrading iPad to iOS 8: Through iTunes 1. Backup your iPad
Open iTunes. Select your iPad in iTunes and click Back Up Now.
2. Restart your iPad and your Computer
3. Download and Install the Update
Go to iTunes -> Select iPad -> Check for Update -> Click Download and Update
Whichever method you choose, the process will take quite some time to work depending on how much free storage you have on your iPad, your internet connection, and how Apple's servers are doing with upgrades. Occasionally, Apple will either not let you download the upgrade or it will fail. For iOS 8, you must have an iPad 3 or newer. This does not work with the original iPad - if something goes wrong, restart your device, and try again.
How to Upgrade to iOS 7 on an iPad or iPad Mini
How to Install iOS 8 When Your Device is Low on Storage need-download-ios-8-0-1-apple-ipad-keeps-u3wnnnxjlb3ct0ebur4t0xqn-1-0.jpg
Sep 26, 2014 | Apple iPad Tablets & eReaders
Error 8007139f
i had the same problem and my system wont work and wen i turn on my tablet it says. tablet useless now f6bc4264-7e1c-4f20-94ab-44397ef30af8.jpg
Jun 12, 2014 | Dell Venue 8 Pro Tablet Computer
My proscan tablet keeps crashing. It says google play has stoping working. I've reset the tablet twice. what can I do?
Keeps crashing because can't handle too many tasks at one time. I have the same problem. I have the same problem. Try the pin hole reset next to the HDMI input . Press in gently with a paper clip and hold for thirty seconds.
Google play? Try uninstalling updates. Disconnect from internet when not in use.
These tablets have lots of problems not easily solved because there are no firmware updates for this model.
May 25, 2014 | Proscan 10.1-Inch Internet Tablet,...
I dis a factory reset on my Proscan 8 PLT8235G tablet. Now, I can't install or update any apps. What do I do to fix this?
Not being able to update any apps simply means either you don't have access to the internet or that your apps update is programmed to function ONLY when you are connected to/through WiFi.
second, you can download standalone 'raw' apk files online and install on your tab.
Remember to go into your Settings---Security (and under Device administration, check 'Unknown sources' and activate 'allow installation of apps from unknown sources'.
Done.
This is safe.
Post update or feedback please
Mar 06, 2014 | Proscan 8 4GB Android 4.1 Tablet
My emerson em543 tablet will not keep the correct date and time
Unfortunately, the only way I've found is to set it to sync automatically via wi-fi. It always resets to 1-1-1970, 12:00, but after it connects to the internet, it sets the correct time. It's a headache, I know. My sister has an 8" Polaroid tablet that DOES keep the right time, so I'd suggest trying out the 4.3" Polaroid tablet if you're set on having one of these budget mini-tablets.
Jan 08, 2013 | Tablets & eReaders
My new zte v9 wont connect to the Internet
Dec 02, 2012 | ZTE V9 Smartpad Android Internet Tablet
Tablets & eReaders Logo
73 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
