Question about Plantronics Radio Communications
Plantronics headset 0 seems to put me on hold hit talk and person is still there
SOURCE: H500 bluetooth headset
Turn down the volume on the PHONE, not the headset. Motorola 325i w/ H500. Again, turn down the volume on the PHONE, not the headset. In my case almost all the way down.
Posted on May 02, 2007
  • 3 Answers
SOURCE: Plantronics headset S10
First, try a headset that you know works.
Posted on May 10, 2008
SOURCE: LG VX-9700 and bluetooth headset cuts out and choppy
Solution is questionable. Talked to Verizon Tech (Good support) and shortly to Plantronics. Both claimed to know nothing of a problem with the LG Dare and Bluetooth. Went back to the Verizon shop in the Mall to get it checked. We duplicated the problem on both phones and also used their phones (not the VX-9700). So, they are sending two new LGs to us via FedEx. When we came back to pick up the phones, the Tech did some research and did find info (Verizon) and Bluetooth. He did not elaborate.
Also there IS a Firmware Update for the VX-9700 and you must take it in to a Verizon that has a flash machine to upgrade the probably 03 to the latest, 05.
Thanks Also, hope this helps someone else experiencing Bluetooth problems.
Lou
Posted on Oct 04, 2008
  • 3 Answers
SOURCE: NBX 3102 Headset jack stops working
You should be using a plantronics a-10 interface cable if you are using hardwire headsets. get rid of the m-20 amplifiers. I support 280 of these phones and the best solution is to replace the phone. Power cycling the phone will help for a while but the problem will come back.
Posted on Mar 24, 2009
keekus
  • 83 Answers
SOURCE: plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Posted on Jul 18, 2009
Can sync earpiece to base. Please help.
Here are the pairing instructions for your Plantronics Voyager 500A base:
On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light start to flash.
Now put the headset into paring mode that you will be using with the base.
Pairing is complete when the talk/on line indicator on base illuminates solidly.
Here is the link to the 500A user guide:
Plantronics Voyager 510S User's Guide
Good luck from Headsets Direct!
Jun 20, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Morning, my headset will put call on hold then i have to hit the "headset" button again on my phone to bring caller back
The CS70 headset only has the ability to mute a call. If you're phone is being put on hold when using the unit, you need to check and see how everything is configured. The user guide below will help you make sure everything is connected correctly.
Plantronics CS70 User's Guide
Mar 28, 2011 | Plantronics CS70 Wireless Headset
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
My iPhone 4 bluetooth won't discover the plantronics 220 Bluetooth earpiece for pairing. Both devices are on including bluetooth on my phone
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I am having a hard time pairing my Plantronics 233 with my Iphone 4...it has been saying "searching" for 10 minutes, but it is not finding my device.
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Dec 17, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Does the Plantronics 903 compatible with iPhone 4. How do i pair it with my iPhone 4
Dec 17, 2010 | Plantronics Backbeat 903 Bluetooth...
Cutting in and out. best described as sounds like i am talking into a fan.
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions:
Plantronics Voyager Pro User's Guide
http://www.headsetsdirect.com/plantronics-voyager-pro-bluetooth-pairing-instructions
Also if you have a different phone available just to test, see if it does the same thing.
Sep 15, 2010 | Plantronics Voyager PRO Bluetooth Headset
I have a plantronics 520,
Start with your headset turned off. Press the talk button on the headset. Hold it until you see the light on the headset begin to rapidly blink red, blue, red, blue, red, blue, etc. Let go, the light should continue to blink red and blue. Go into your phones blue tooth menu and search for the headset. The phone will only find the headset if the headset is in pairing mode (blinking red and blue). The pass key is 0000.
Apr 10, 2009 | Plantronics Hama Voyager 520 Bluetooth...
Cannot connect my plantronics discovery 925 to my i580
In order to connect your i580 to this headset you must hold down the power button on the plantronics headset while you choose link to devices. If you just power up the headset then try to pair it you will not be able to discover it. you must hold in the headset powwer button the entire time you are linking the device. After your phone finds the 9XX headset you can bond the device using a passkey of 0000.
Nov 11, 2008 | Cell Phones
May 10, 2008 | Plantronics (45647-04) for S10, T10, T20...
Radio Communications Logo
29 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
