Question about The Computers & Internet
What has the greatest solubility - The Computers & Internet
How will a solution of salt mixed with isopropyl alcohol react wtih aluminum
Common salt is not very soluble at all in isopropanol, being about 1/2800 that of water solubility. Hence you will have a suspension, really. Given that the alcohol is also not terribly active as an electrolyte, and provided the aluminium is well wetted all the time, you should get little corrosion.
However all alcohols are hygroscopic, and if your isopropanol has a significant water content, this will combine with the salt. Then you will see two distinct layers present, and the salt-water solution will have a corrosive effect on the aluminium.
Jul 11, 2014 | Computers & Internet
Means able to dissolve in a certain solvant
soluble in.........
eg salt is soluble in water
Apr 27, 2014 | Computers & Internet
What are the different types of fertilizer?
There are 4 types: organic, granular, synthetic, and water soluble.
the following information is quoted from the website listed below:
Organic fertilizers are made from natural ingredients and have a slow release, meaning that the materials in these fertilizers must be broken down by soil microorganisms for the gradual release of nitrogen and other elements. Dry, granular fertilizers are the most popular type and work by releasing small quantities of nutrients each time the plant is watered. Water-soluble fertilizers are easy to apply and make nutrients immediately available to plants. Synthetic fertilizers act fast and provide an immediate greening effect, although the effects may be shorter lived.
  • Organic fertilizers contain lower nutrient levels than other types of fertilizers
  • Organic fertilizers are the least likely to cause "fertilizer burn" on plants
  • Granular fertilizers work well for vegetables and perennials
  • Use water-soluble fertilizers with annuals and container plants
  • Synthetic fertilizers are easier to transport and are less bulky than organics
Feb 14, 2013 | Garden
Should fat soluble vitamins be taken with food?
in order for fat soluble vitamins to be absorbed in the body, they need to be taken with fat. So you should take these vitamins (Vitamin A, D, E, and K) with your meals that contain fat.
Feb 04, 2013 | Health & Beauty
What is the difference between water soluble vitamins and fat soluble vitamins?
Water soluble vitamins are vitamins B and C, while fat soluble vitamins are A D, E, and K. The difference between these two types is the way they act in the body. Water soluble vitamins are vitamins that our body does not store and once they are consumed, they go straight to the blood stream. Because they cannot be stored, it is important to consume these vitamins on a regular basis. Fat soluble vitamins on the other hand are stored in our body by dissolving in fat. They are used when needed and the rest is maintained in the body for future use.
What is the 2 classification of vitamin
These vitamins are soluble in fats, oils and in fat solvents like alcohol, etc. There are four fat soluble vitamins. They are: Vitamin A, Vitamin D, Vitamin E and Vitamin K.
These vitamins are stored in liver and are not readily excreted in urine and are not absorbed in the body unless fat digestion and absorption proceed normally. Among all the four vitamins only Vitamin K has a specific coenzyme function. Fat soluble vitamins are made up of one or more carbon units and hence they are called Isoprenoid compounds.Their deficiency can cause malabsorptive disease.
Excess intake of these vitamins may cause hyper vitaminoses. Water soluble vitamins
These vitamins are soluble in water. They are again divided into B complex vitamins and non B complex vitamins. B-complex vitamins are - Thiamine (B1), Riboflavine (B2), Niacin (B3), Pyridoxine (B6), Biotin (B7), pantothenic acid, Folic acid and Cyanocobalamine (B12). Vitamin C is the non-B complex vitamin.
These vitamins are not stored in the body (except B12). Hence, they are to be continuously supplied in the diet. The biochemical reactions of these vitamins is through co-enzymes. The common deficiency symptoms of these vitamins are Dermatitis, glossitis, diarrhea, depression, etc.
Jul 12, 2011 | Computers & Internet
Find largest number given three numbers in visual basic
enter a;
enter b;
enter c;
if a>=b and a>c
print "a is the greatest number"
then if b>=a and b>c
print "b is the greatest number"
then if a=b and a=c
print "a, b, c are equal"
if not print "c is the greatest number"
this is pseudocode.. or my drunken attempt to remember pseudocode... but I think the logic could work.
Nov 27, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
