KDL40EX520 LED BLINK 3 TIMES WHEE IS THE PROBLEM IN POWER BOARD OR LOGIC BOARD
hemantraj
  • 638 Answers
SOURCE: my KDF-55WF655 power led blinking red six times.
oh ho try a hard reset mostly u will solve.
Posted on Jun 13, 2008
  • 52 Answers
SOURCE: power supply board led green light blinks 3 times.
vscan is a voltage used to setup the picture for the panal. It goes to the y sus board. The problem is at the power supply or the y sus board. You can check these with a meter.
Posted on Aug 12, 2008
  • 52 Answers
SOURCE: TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Posted on Aug 19, 2008
  • 138 Answers
SOURCE: 42PF5321D/37
Measure the connector from the logic board to the power supply the second pin from the left it will say Vs_ On if the set has 3.1 volts the problem is the SSB or the logic board. On the logic board there should be a solid led and a flashing led that shown that data id flowing and the problem is the SSB. The SSB is easy to replace just remember what you tokk loose and from where. You probely will save money that way. If the set is in warranty or just out of warranty contact Philips 1-888-744-5477 and see what they can do first.
Posted on Aug 20, 2008
phil_frye
  • 295 Answers
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
Posted on Nov 22, 2009
3 time blink sony - Sony 40 KDL40EX520 LCD TV what is the problem
try a power reset first. 3 flashing light is bad main logic or power board ,check for standby volts if ok replace main logic board
May 14, 2017 | Sony Televison & Video
Error code 5100
There is no error 5100 in the manual so look at the following:
(1) Operator call errors (by LED blinking in orange)
LED blinking in orange. Error Solution Remarks
2 times No paper. Set paper, and press the Resume/Cancel button.
3 times Paper jam. Remove the jammed paper, and pressthe Resume/Cancel button.
4 times No ink. Replace the empty ink tank(s). (Pressing the Resume/Cancel button will exit the error without ink tank replacement.)
5 times The print head is not installed properly. - Install the print head, and close the
front cover.- With the print head installed, turn theprinter off and on.
- Re-install the print head.
8 times Warning: The waste ink absorber is almost full (approx. 95% of the
maximum capacity). Pressing the Resume/Cancel buttonwill exit the error, and enable printing.
In repair servicing, replace the bottom case unit (QM2-0647), or 5-item set of
the ink absorbers
(QA4-1012/1013/1014/1015/1055).
The service call error, indicating the waste ink absorber is full, is likely to occur soon.
9 times The connected digital camera or digital video camera does not support
Camera Direct Printing.
After removing the cable between the camera and the printer, press the Resume/Cancel button, and re-connect the cable.
(2) Service call errors (by LED blinking alternately in orange and green, or lit in
orangeLED alternate blinking in orange and green
Error Solution
(Replacement of listed parts, which are likely to be faulty)
2 times Carriage error - Carriage unit (QM2-0655 / QM2-0831)
- Timing **** strip film (QA4-1053)
- Logic board ***'y (QM2-0750 / QM2-0751)
- Carriage motor (QK1-0175)
3 times Paper feed error - Timing sensor unit (QG4-0277)
- Timing **** disk film (QC1-2781)
- Feed roller ***'y (QF4-0155)
- Platen unit (QM2-0650 / QM2-0828)
- Paper feed motor (QK1-0224)
4 times Purging error - Purge unit (QM2-0825)
6 times Internal temperature error - Logic board ***'y (QM2-0750 / QM2-0751)
7 times Waste ink absorber full - Ink absorber (QA4-1012 / 1013 / 1014 / 1015 / 1055)
- Bottom case unit (QM2-0647)
8 times Print head temperature rise - Print head (QY6-0042)
9 times EEPROM error - Logic board ***'y (QM2-0750 / QM2-0751)
13 times USB Host VBUS overcurrent - Logic board ***'y (QM2-0750 / QM2-0751)
- DCD board ***'y (QM2-0825)
15 times Other hardware error - Logic board ***'y (QM2-0750 / QM2-0751)
Continuous alternate blinking
Flash ROM error - Logic board ***'y (QM2-0750 / QM2-0751)
Lights in orange
RAM error - Logic board ***'y (QM2-0750 / QM2-0751)
Hop you can understand the above as it is straight out of the service manual.
Good luck
May 24, 2011 | Canon BubbleJet i560 InkJet Printer
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
The yellow lamp is flashing and printer dosn't work .My printer is pixma mp510 canon
How many times does it blink... 2, 3, 12....
2 times Carriage error [5100] An error occurred in the carriage encoder signal. - Carriage unit (QM2-3753)
- Timing **** film (QC1-9542)
- Logic board (QM2-3827)
- Carriage motor (QM2-3872)
3 times Line feed error [6000] An error occurred in the LF encoder signal. - Timing sensor unit (QM2-3878)
- Timing **** disk film (QC1-9597)
- Feed roller (QL2-1407)
- Paper feed motor (QM2-3873)
4 times Purge cam
sensor error
[5C00] An error occurred in the purge unit. - Purge unit (QM2-3754)
5 times ASF (cam)
sensor error
[5700] This error takes place when feeding paper from the
ASF after an error occurred in the ASF cam sensor.
- Sheet feed unit (QM2-3762)
- ASF_PE sensor board (QM2-3877)
6 times Internal
temperature
error
[5400] The internal temperature is not proper. - Logic board (QM2-3827)
7 times Ink absorber
full
[5B00,
5B10,
5B01,
5B11]
The ink absorber is full.
Error codes:
Overseas:
5B00: Main ink absorber
5B10: Borderless-print ink absorber
Japan:
5B01: Main ink absorber
- Ink absorber kit (QY5-0178)
1-5
Note: Before replacement of the logic board ***'y, check the ink absorber counter value (by service test print or EEPROM information
print). If the counter value is 7% or more, also replace the ink absorber kit (QY5-0178) when replacing the logic board ***'y, or
register the current ink absorber counter value to the replaced new logic board instead. [See 3-3. Adjustment / Settings, (9)
Service mode, for details.]
2-3. Other Error Messages
5B11: Borderless-print ink absorber
8 times Print head
temperature
rise error
[5200] The print head temperature exceeded the specified
value.
- Print head (QY6-0070)
9 times EEPROM
error
[6800] A problem occurred in writing to the EEPROM. - Logic board (QM2-3827)
10 times VH monitor
error
[B200] The internal temperature exceeded the specified
value.
12 times PG position
error
[5C10] An error occurred in the PG motor during purging
operation.
15 times USB Host
VBUS
overcurrent
[9000] The USB Host VBUS is overloaded. - Logic board (QM2-3827)
19 times Ink tank
position sensor
error
[6502] None of the ink tank position is detected. - Spur base unit (QM2-3750)
20 times Other
hardware error
[6500] The PCI bus error is detected by the ASIC. - Logic board (QM2-3827)
22 times Scanner home
position error
[5010] The scanner unit cannot detect the home position, or
the scanner unit warming-up is not performed
properly at power-on.
On the LCD, "Scanner is not operating correctly." is
displayed.
- Scanner unit (QM2-3775)
Alarm and Power
LEDs lit
ROM error,
RAM error
A flash ROM or RAM checksum error occurred at
hard-power-on.
Jan 12, 2010 | Canon PIXMA MP510 All-In-One InkJet...
42PF5321D/37
Jun 23, 2008 | Philips 50PFP5332D 50 in. Plasma...
Philips 42pf7320a/37 dead
Error 7 is a power related problem. This is what u need to do.
Remove back cover.
Plug in power when tv goes into error protection, check power supply and see how many times the led flashes. Right below the flashing green led there is a list 1-13 of error codes and what they mean. Your problem will probably be an error 7or 8 VSET or VSCAN . Which ever error code it gives you VA VSET or VSCAN or whatever it indicates look at the cable connectors to the power supply unplug that connector and the TV will stay on. And there will be your problem.
May 06, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
New logic board installed cant install driver
After installing a new i9900 logic board, you *must* configure the destination country setting. The default setting is probably for Japan (PIXUS 9900i):
1. With the printer powered off, hold down the resume button and press the power button.
2. While holding down the power button, release the resume button and press the resume button two times. Now release the power button. The LED will blink green and remain lit in green. You are now in Service Mode.
3. Press the resume button 5 times to get to Model Setting mode. The LED will turn orange. Then press the resume button two times to set the model number to i9900 (LTR). Press the power button once to lock in this setting and turn off the printer.
Apr 14, 2008 | Canon i9900 InkJet Photo Printer
Kv24fs120 dead set with two led blinks
Two-blinks of the "Diagnostic STANDBY/TIMER LED" indicates one of two things:
1) Horizontal Output (Q502) in shorted on the A-board.
or
2) IC702 is shorted (CB board)
Two-blinks of the diagnostic red LED is a " B+ Overcurrent" problem.
The red LED will blink 2-times, stay off for 3 seconds, then blink 2-times. The cycle repeats.
The circuit board is quite delicate. One should not attempt repairs (unless one has high quality vacuum desoldering equipment such as a PACE desoldering unit).
Feb 01, 2008 | Sony KV-24FV12 24" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
