Question about Proscan Televison & Video
My Proscan 55 inch LCD tv has a blank screen now. any way to trouble shoot?
It's less then a year old. it was working without issues then one day I turned it on and screen remained blank instead of the traditional blue screen with PROSCAN written on it. Still receiving audio.
  • 814 Answers
SOURCE: I have a 32 inch Proscan LCD tv. Is there any way
I found this solution on the PROSCAN website. www.oncorpus.com.In the customer support section, under manuals for you model of television. I hope this information helps you with your problem. Press MENU on the front panel or on the remote control and then use the up and down arrows to select the AUDIO menu.Press the enter button to enter the function.
1. Use the up and down arrows to select what you want to adjust in the AUDIO menu.
2. Press ENTER button to select it and then use the right and left arrows to adjust
3. When you are satisfied with your adjustment, press MENU to exit the main menu.
Audio Mode.
Posted on May 21, 2009
SOURCE: remote code for comcast dvr/proscan tv
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
Posted on Jun 06, 2009
SOURCE: Proscan 32'' VGA port; TV says not supported on VGA input
Sounds like your resolution on your computer is set too high for your tv to accept. Try putting your computer resolution down to 1024x768 or lower and see if that works.
Posted on Aug 05, 2009
  • 20 Answers
SOURCE: Proscan 40" LCD-Screen Freezes
They actually state that you have to unplug it and replug it in to fix this problem in the owners manual so it's not just a isolated issue. I to have this problem daily now and this is the 2nd set after returning the first one due to same reason.
Posted on Oct 12, 2009
I keep getting green dots all over tv screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 15, 2015 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Trouble shooting
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Apr 05, 2013 | ViewSonic Computers & Internet
I have a line at the bottom of the screen about an inch up. How can I get rid of it without spending more than the TV is worth.
A reboot or factory reset if possible will not help with that issue---bad connection somewhere or bad display panel (screen unit).
Nov 08, 2012 | Proscan 47LB45H 47 in. LCD TV
Yellowish screen
On a CRT, "yellow" is a mixture of all 3 "primary" colours.
So, if you are expecting some other colour, then one of the 3 "guns" that are emitting one of the primary colours is NOT working correctly.
For less than $100, you can purchase a new, 19-inch (not 17-inch) LCD (not CRT) monitor.
This is less expensive than taking the CRT to a TV/video store for trouble-shooting and repair.
Jan 07, 2011 | Mag Innovision InnoVision 786 PF 17" CRT...
40'' proscan lcd will not turn on
Could of gotten voltage surge
Try anther outlet
Dec 05, 2017 | Proscan 42LA45H 42 in. LCD TV
I have a sony lcd 55" flat screen. We have blue dots in the center of the screen multiplying every day. What causes this exactly. Is it cost effective to repair ? Could I repair it my self ? I have basic...
model # says its a 42" sounds like a rear projection lcd tv not a flat panel its your light engine sony will replace it free if its less than 5 years old
Feb 03, 2010 | Sony KDF-42WE655 Television
My Video 55 player will not play my videos
You need to switch the video out seeting on the iPod, simple. It is located in Video/video settings/TV Out. Change the setting to "On". Problem solved. However, if you have an iPod that is less than 1 year old, nothing will work, iPod blocked this ability to change to "On" and is set on "Off" permanently.
Mar 04, 2009 | Sonic Impact Technologies Sonic Impact...
It's the 26 inch version but have problem with picture
Hi Paul,
It looks like your TV might have a main board failure if the screen stays white without video. Since your TV is less then a year, I would suggest to contact the manufacturers to get fix under warranty. Most electronics devices carry one year warranty.
Good Luck.
Dec 19, 2008 | Olevia LT32HVE 32 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
