Question about Cell Phones
I wish to set up my phone. - Cell Phones
Magic jack customer service
Access the phone with number you wish to forward, get to the forward settings then type the phone number you wish to forward to.
Aug 25, 2014 | Computers & Internet
Set rings for daytime voicemalil
Try setting to 3-4 rings and see if vociemail kicks in , if not try reseting the phone
Jul 26, 2012 | AT&T Lucent MLS-12D Phone
ZTE N762 Reset
Menu>Apps>Gallery>Themes>Scroll to Theme that you want to delete and press options>Delete
After that you select and hold the application which you wish to delete and..." Here is what you have to do in order to delete/remove/uninstall (call it whatever you want) themes from your Nokia C5-03: Menu - Settings - Application Mgr. - Installed applications - then you will see the installed app. in your phone, after that you SELECT and HOLD the application which you wish to delete and after you do that a Pop-Up wish appear written UNINSTALL in it, you then select Uninstall - YES and the application will be removed from your phone. Use the same way to delete songs too, just SELECT AND HOLD the song you wish to delete and the pop-up will appear, you then should click DELETE and job done ;) Hope i was clear on this explanation and wishing this will help you!
Feb 24, 2012 | ZTE Cell Phones
Why am I being required to type a secret code when the Motorola i1 needs a master reset? Any clue?
Any branded phone is required to enter your code if they wish to reset the phone setting for security purpose. other user can't access,erase or reset your phone if you put a code on it.
if you doesn't know the phone code of yours,
* phone or unlock code is set in 4 digits,for locking some features like message,photo,video and other data you wish to lock up, 1234 will be the default.
* for security code is set in 8 digits,for securing the entire phone settings, 00000000 will be the default.
If you wish a "master reset" ,be sure to back up all necessary data because everything will be gone.
thank you for visiting FixYa..
Jun 16, 2011 | Motorola Mobility i1 Smartphone
Ringer is off/cannnot hear incoming calls - instructions does not include how to turn the ringer back on
hello,you have to go to your phone settings,then you go to the phone ringer settings,you then set the ringer settings to the step you wish.
that will make your phone ringer work as expected and supposed.
wish you good luck,
take care.
Aug 13, 2010 | Cell Phones
Phone is not ringing
Sounds like the system programming defaulted. If thats the case then you'll need to reprogram the ringing on the other sets.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Jun 07, 2010 | Samsung 616 24 Button phone
Some 816 phones won't ring on incoming calls
Jun 05, 2010 | Samsung Prostar 816 Phone
Sir i wish to format my phone memory. i know the number *#7370# but it ask restore settings but not formating...(nokia 6670)
Yes, it all means the same thing. Factory restore setting will format your phone to factory default, that is, the way it was when you first bought it.
But here is my country, we could also use the format phones by inserting the cable of the phone into it and the the USB part in the computer, but the drivers/software for the model of the phone must be available to do this.
So you can try it as well if you have all it requires or better still you continue with the restore settings.
Wish you the best.
Nov 12, 2009 | Computers & Internet
I want to know how to set up my gprs
You need to contact for this the Serivce Provider on your Cellular phone. then will provide you the required settings.
Best wishes Scott
Jan 04, 2009 | LG Prada KE850 Cellular Phone
How to set up greeting w/o automated instructions & options
not possible that is a built-in feature on the phone
Dec 24, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
