Question about Car Audio & Video
The push down controls on my DLC7 have been pushed in towards the machine when it was packed in a suitcase?
The machine is a Cuisinart Food Processor.
3 Suggested Answers
  • 10865 Answers
SOURCE: Address for Cuisinart food processorrepair in Philadelphia??
Hello. Go to this link
there u have all of the contact info. Call customer care at Cuisinart and they will assist you directly. J.
Posted on Jun 26, 2010
  • 93 Answers
SOURCE: my cuisinart food processor doesnt
Try making sure the attachments are "locked" in placed.
Posted on Jul 09, 2011
Problem with My Cuisinart 4 cup Mini Prep plus processor The pushing assembly does not go in all the way down
Turn the piece(s) over and look for food or other obstructions lodged in the mechanism.
Dec 02, 2017 | Cuisinart Food Processors
Is the Cuisinart DLC 7 Super Pro Manual available to download?
Manuals can be found here:
Food Processors Product Manuals Cuisinart com
You'll have to look around at the options and pick one that looks like the one you have.
If you have an older one, the handle for the bowl generally goes in front, and check the base to see if the button that gets pushed down when the top is in locked position is in the front or the back... and try to match that. The DLC-10s has it in the front (7 cup machine), but many of the larger machines have it in the back. The feed tube matches up with the button when you put the lid on. If you put the lid on with the feed tube 180 degrees off, you can break the lid/bowl getting them apart again.
Getting this right is the most important thing... otherwise they just kind of work. The link for the 7-cup Pro Classic Food Processor (DLC-10s) has really good technique information with color photos. It's worth grabbing regardless of the machine you have.
Other manuals have other recipes... so you might want to download more than one manual.
Jul 03, 2014 | Cuisinart DLC-5 Food Processor
Why Cuisinart mixer will not start?
All Cuisnarts have an interlock rod built in to the bowl assembly.
Make sure the bowl is positioned on the motor base correctly, and the actuator in the lid that pushes the interlock rod down is not bromen or damaged. If it is intact and working correctly, then check the switch it pushes on, or the main power switch.
May 20, 2014 | Cuisinart DFP-11 Deluxe Food Processor
Jun 26, 2010 | Cuisinart DLC-5 Food Processor
I have a cuisinart pro classic food processor, and even though bowl and top are locked in place, it will not start.
On the processor look at the bowl and lid and see where they are supposed to engage the motor. If this is broken then that is the problem, find something to push on where the part of the the bowl and lid assembly would push, if it comes on then you have figured out the problem.
Apr 17, 2010 | Cuisinart DLC-10S Pro Classic Food...
Won't start
Make sure the work bowl handle is locked in place so that it is facing the front of the processor (same side as the on and off switches).
Make sure the feed tube of the lid is facing toward the back of the processor and that the plastic or metal rod of the pusher sleeve is facing the back of the processor.
Note: this assembly only applies to the Cuisinart DFP-14 series - every Cuisinart has a slightly different assembly for it to turn on.
Sep 13, 2009 | Cuisinart DFP-14BC Custom Food Processor
My food processor light is on but i need to press and hold the black button please help
Use a ball-point pen to depress the button - your finger simply will not do.
This is only to test the motor.
Once it makes the proper sound, you are ready to assemble the workbowl - once properly assembled, the workbowl, lid, and pusher itself will push the button for you. On the DLC-2011, the proper assembly is for the work bowl handle to be locked toward the front of the processor. If you are still having trouble or you have a model other than the DLC-2011, call Cuisinart at 1-800-726-0190 and they will help you with the assembly.
Aug 18, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Appears to be locked but won't turn on
ah! well my mother just tried using her DLC-10S 7 cup food processor and she also encountered the same problem. It worked perfectly fine when she first used it around Christmas time but not anymore.
After almost smacking the hell out of it we discovered that there is a plastic tab on the lid towards the handle side. This plastic tab actually pushes a lever through the cup and into the base of the food processor.
New Bee actually mentions this above. The problem is that the flimsy plastic tab in the handle isn't stiff enough to push the lever down anymore. I'm amazed it worked the first time.
This is very much a design flaw by Cuisinart as there's no way this plastic tab would ever last.
Now there is a small opening in the case right above the plastic tab. To get our food processor going we just pushed a chopstick down on the tab and held it in place while the food processor runs.
This is very much a temporary solution until we get a new food processor, obviously a different model.
Nov 22, 2007 | Cuisinart DLC-10S Pro Classic Food...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
