Question about Philips Televison & Video
Is philips tv series 4000 HDCP compatable? - Philips Televison & Video
2 Suggested Answers
  • 74 Answers
SOURCE: Keep telling me lost hdcp. It's been working. TV PHILIPS plasma
it sounds like your cable is going bad or your tv/360 might not be on a HD setting
Posted on Sep 05, 2009
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
Hdcp error mesage when connected to my freeview hd box.
What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
Nov 22, 2010 | Televison & Video
Does this tv support HDCP
The specs do not list HDCP compatibility on the HDMI/DVI port. Thus it probably doesn't support the feature.
I wish that I had better news.
Nov 19, 2010 | RCA HD50LPW175 50" HDTV
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Apr 27, 2009 | Video Game Consoles & Games
Unable to use Sky HD Due to an HDCP
Try calling samsung they might have a firmware update they can send you
Dec 06, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Hdmi port
Philips has a complex HDCP key on its HDMI ports that makes it a bit "glitchy" when compared to other manufacturers. Usually the problem can be fixed by swapping the ends of the HDMI cable - the end that is plugged into the TV should be plugged into the Philips, and then end that is currently plugged into the Philips should be plugged into the TV. This is called "hotswapping," and will turn off a specific HDCP setting that is interfering with the functions.
Also, perhaps first even, make sure the Philips source is set to HDMI - press the HDMI button on the Philips remote.
-Tha Mp3 Doctor
Sep 17, 2008 | Philips DVDR3576H DVD Recorder
Philips 32' lcd hdtv
are you using a DVI to HDMI converter? Radeon cards older than x1*** series or roundabout didnt support hdcp on dvi which is required to run Hi-Def rez thru an HDMI cable on most TVs. A video card with hdmi prebuilt in or HDCP compliance listed on the box should be able to handle it. And you should find a resolution both your normal monitor and HDTV can handle to set the coimputer to before you switch it over to the HDTV to be sure it will still show you picture. If you arent using 1080P you might as well use a component input which doesnt require HDCP.
Oct 12, 2006 | Philips 32PF9966 32 in. HD-Ready LCD...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
