My control panel missing - Computers & Internet
  • Richard May 14, 2017
    Hi Harry Van der Merwe, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Are you using Windows 7, 8 or 10?
Graphire 3 vista
If control panel is totally missing, your OS may be corrupted or you may have a virus.
Nov 13, 2013 | Office Equipment & Supplies
My ac heat panel in my 1998 suburban missing
Autozone will never carry any part like this.
May 25, 2012 | 1998 GMC Suburban
I do not have audio on my acer aspire t135 pc. my speakers are plug in but i did notice that on my control panel:add/remove programs that the realtek ac'97 is missing
If you are missing drivers (you should go to the control panel and sounds to check this) are missing, you can download them from the Acer site.
Also, check this link for troubleshooting:
http://www.fixya.com/support/r8990527-no_sound_coming_from_speakers
Jun 23, 2011 | Acer Aspire T135 PC Desktop
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
Missing multimedia audio controller
what do mean of missing multimedia audio controller? the one that speaker icon on the lower right of the monitor or driver for the multimedia? Go to control panel then sounds and audio devices then on the volume check the Place volume icon on the task bar... hope this will help
Nov 03, 2010 | Computers & Internet
Missing language on pc .i go to control panel to language and regional but the language is missing
Hello.
Give this a try:
Click Start -> Control Panel -> Regional and Language Options.
Click the "Keyboards and Languages" tab, and then click "Change Keyboards".
Here, under the General tab, you will have to add a secondary language to your keyboard, if not you will not be able to view the language bar. To do this click Add, and select the language you wish to use, click OK.
If this does not help, or you do not have Vista, please let me know.
Oct 10, 2010 | Computers & Internet
Tally 6100 missing lines
horizontal or vertical characters missing???
if your missing horizontal lines, look at where the print is missing if you see imprints... u have bad ribbons.
if your missing vertical characters down the page
Power off the printer & unplug from wall
Remove with phillips the top right cover. u will see that the control panel has a plastic clip needs to be pressed in for the control panel to come loose from the top right cover.
Then you will see P703 Hammerbank Ribbon Cable and
P704 Hammerbank Ribbon Cable swap these 2 cables on the Engine Controller Board part# 083368.
IF your missing characters move to another place on the printout then u will need to replace part# 083368.
IF your missing characters are still in the same place, then you will need to replace hammer module part# 081152, their is qty 11 of the individual 081152 about 1 inch wide. this will save $$$ ordering and replace 081152 if you have some at your work semi technical.
Be very careful with hands when powering the printer with the top right cover off
Electrically and mechanically.
Need more help you may call Toby at x311
Apr 24, 2009 | Tally Line Matrix T6100 Printer
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
