How to find and use the guide on the remote - Televison & Video
Orion model 1331 user guide
Sue, cross referenced your remote to a Cisco remote, manual link below. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.cisco.com/c/dam/en/us/td/docs/video/at_home/Set-Tops/DTA/4030042_B.pdf
http://www.orion.newremotecontrol.com/OrionTV.php
Welcome to Remote Central Universal Remote Control Reviews More
How to Program Universal Remote
Codes for Universal Remotes
Apr 10, 2016 | Orion Televison & Video
Remote guide is locked on pay per view channels (#600's)
call your satellite or cable provider, they'll walk you thru on how to fix it
Jun 11, 2010 | Logitech Harmony 520 LCD Remote Control
I want to set my remote to only the chanels I recieve
you can press the guide button, when your guide comes up look under list or fav list and press teh guide button till you see ALL SUBS. and you good to go!
Oct 16, 2009 | DISH Network IR Remote Control
Remote up & down channel buttons will only bring up a few channels. Cannot go through all channels unless I punch in digits on remote
Which Dish model receiver and remote? You likely have a custom guide selected that only includes those channels. On most models, press guide twice and select a different guide or press Favorites to Modify List of the channels in the current guide. If in doubt select All Sub or All Channels to see more/too many channels with up/down. I use All HD for seeing the high-def channels. Otherwise I use a custom list to see a bigger listing. -Ken
Aug 25, 2009 | DISH Network IR Remote Control
Cannot get channel guide to show
Besides the many features Osiris MX-350 provides as a universal remote control, it is also a learning remote.
If pushing the button doesn't have the expected result, e.g. pushing the GUIDE button on the remote doesn't bring up the channel guide, you can teach the Osiris with the original remote.
Instructions on teaching your remote a new command is included in the instruction manual.
Since I couldn't find a code for my Sony blu-ray player, I just taught the Osiris all the commands from my original remote in about 10 minutes.
Aug 16, 2009 | Universal Remote Control Osiris Complete...
How to bypass the tv guide plus loading without a remote?
you need to have a "tv Guide" compatiable remote. check out some of the old sytle RCA remotes at your nearest electronic store, look for the tv guide symbol on the box.
Aug 07, 2009 | Televison & Video
Remote quick start guide
The manual and the quick start guide can be downloaded in PDF from this link:
http://www.retrevo.com/support/Philips-SRU9600-Universal-Remotes-manual/id/633dj683/t/2/
If you are successfully using the remote already then there is probably no need for the quick start guide. If this helped you please rate me.
Take Care,
-WN
May 06, 2008 | Philips SRU9600 LCD Touchscreen Remote...
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
