Question about Health & Beauty
My scooter dies when i put it in gear - Health & Beauty
Replaced batteries 18 mo. ago. light comes on when I put key in, but scooter will not move. Mechanic said I need another battery. I* have used the scooter about 5 times. what gives
Batteries are dying the moment they are born, like humans. The sulfation process is what does it and when a battery is not used it will discharge - most lead acid batteries do not like to be in a state of discharge and they die faster than normal.
Replace the battery and get a battery tender to attach to it during the periods the scooter is not used.
Apr 12, 2017 | The Health & Beauty
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Mother's scooter keeps dying
How old is the battery they don't last forever and they are not cheap
Sep 28, 2015 | Pride Go-Go Elite Traveller 4-Wheel Travel...
My gogo ultra is showing fully charged and horn beeps, when i put key in it beeps fast 10 times and 5 beeps after
5 beeps usually means scooter is out of gear, but since the lever is in the drive position and the scooter gearbox/differential is engaged, it seems that the controller is not sensing the gear change. Possibly a faulty micro switch in the motor housing can be the cause of this, usually the micro switch is pressed down by the drive lever and if the switch is pressed down the motor controller knows the scooter is in gear.
Feb 11, 2015 | Pride Mobility Products GoGo Ultra X...
How to take scooter out of gear
mix the correct amount of oil use GOOD OIL "KLOTZ" yamalube,goldenspectro ect... use PREMIUM FUEL and it will idle better, so you can turn the screw to idle slower ,but most will spin a lil no matter what its automatic i bet ,if its real bad the springs for the auto clutch are prolly weak
Aug 28, 2014 | Motorcycles
THE TRUCK STARTS UP FINE, BUT DIES WHEN IT IS PUT INTO GEAR
if it dies when put in gear, try giving it gas while holding the brake, them putting it in gear if it does not die then replace the idle control valve iac it located on top on the throttle body
Dec 20, 2010 | 1996 Ford Explorer
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
My 49.9 CC WASP Scooter quits whenever I try to climb a hill
Hi. I live in Colorado and just bought this same scooter(used) and I'm having the same problems with it. Have you figured out what the problem is yet?
Mar 20, 2009 | Computers & Internet
Reduction of runtime between battery charges.
The only other things I can think of is a bad motor brush, or a bad gear not turning freely in the gear box. I am not as familiar with the drive scooter, but it should have two caps on the motor that have brushes in them. The brush is held in by the cap, unscrew it and take brush out ( it is spring loaded) and check contacts. If it is worn down too much or unevenly worn it needs to be replaced, also if the spring is not set right or the brush is stuck it will cause drag, Put the brushes back in the same way you took them out if they are good, if you need to replace you need to wear them in by putting rear wheels of scooter up on something and run scooter by putting a rubber band on throttle. If it's the gear box it needs to be replaced
Jan 24, 2009 | Drive Medical Health & Beauty
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
