Question about SuperMicro Computers & Internet
How do you change the battery on a supermicro p6sba motherboard, to say the least it's a bit tight!
What battery is used supermicro X5DP8-G2
The most common CMOS (BIOS backup) battery is a CR2032 3VDC battery. Since the X5DP8-G2 and the X5DPR-8G2+ share a manual, I suspect that the CMOS battery is the same for both boards. The picture in the manual for the X5DPR-8G2+ board shows a CR2032 clearly.
There is a link to the manual on the X5DP8-G2 product page: . This link includes a SuperMicro terms of use. The current direct link to the manual is .
The usual way to confirm the battery type for this type CMOS battery on the motherboard is to remove the battery from the vertical slot. Read off the information on the battery and replace it with the correct battery. I usually have a number of these batteries available and don't have to go shopping. After replacing the battery, you will need to access the BIOS and update the time and date information for the system.
I hope this helps.
Nov 06, 2015 | Computers & Internet
There may be a bad connection in the CMOS battery housing. The battery should make an audible click when it's pressed into the CMOS housing on the motherboard. First, I would make sure that the motherboard BIOS has the latest version R2.1c found here:
Super Micro Computer Inc Products Motherboards Xeon Boards X7DA8
If you can't locate a bad CMOS terminal, you may need to RMA the motherboard. You can check the warranty status here:
Apr 18, 2014 | SuperMicro X7DA8 Server Board - X7DA8-B...
We have some problem with Clock system.
change the battery for cmos on board if that dose not work then you need a new board.
Nov 25, 2013 | SuperMicro X5DPL-IGM Motherboard
How much is infinity?
Jun 27, 2013 | SuperMicro p6sba Motherboard
I have a Supermicro P8SCT motherboard when I power it on I get no video
Hello here is the homepage:
When you have a blown cap, on the mainboard i suggest to change them all.
But the price for this, will exeed the price for a new and better mainboard.
A new mainboard cost about 100 dollars, and the cpu aswell.
I suggest you to buy a well known brand like asus or intel.
I`m using asus, and i newer have any problems with that.
Intel is a bit more expensive, than a amd based mainboard.
Good luck
Mar 18, 2013 | SuperMicro P8SCT-RETAIL BOX...
X7DBI+ bios password
Remove the cmos battery on the mainboard for like 15 min. and inset the battery again.
This will clear the bios and remove the password.
But you have to setup the bios clock, date, boot settings, when the pass is gone.
The cmos battery look like this:
Please take antistatic precautions when working on the maniboard.
Good luck
Jan 12, 2013 | SuperMicro X7DBi+ Motherboard
8 gig of ram installed but win 8 pro 64 bit only see 4 gig, Win 7 Home Ultimate 64 bit had same result
Hello the homepage is here:
Check for one of the modules is in place in the ram socket
and blow it out for dust with compressed air.
One of the modules could also have a defect.
The mainboard supports:
Up to 8GB dual channel unbuffered
ECC/non-ECC DDR2 667/533/400 MHz
Try also to upgrade the mainboard drivers with this tool:
Good luck
Oct 29, 2012 | SuperMicro PDSG4 Motherboard
Resolve Error Code: C7 on SuperMicro Server
First check the OS compatibility for you motherboard here:
Then, if compatible, check the IDE/SATA setting. Change the hard drive controller settings from IDE to AHCI or vice versa to see if the OS kernel panics on boot. If that does not work, please reply with your OS version and motherboard model.
Apr 12, 2012 | SuperMicro Computers & Internet
Can i run vista on Supermicro X7DAL-E Dual LGA771
The easyest way to find out would be to download and run, Windows Vista Upgrade Advisor x32-bit. Open the link provided below;
Microsoft windows 7 is faster than Vista.
Windows 7 adviser click on the link;
Hope you find this helpful.
Oct 23, 2009 | SuperMicro X7DAL-E Motherboard
Computers & Internet Logo
42 people viewed this question
Top SuperMicro Computers & Internet Experts
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
