Question about Engel Refrigerators
My Engel works on 230 Volts but has stopped working on 12 Volts. What could the problem be and does someone have schematic for old Engel's
4 Suggested Answers
  • 3 Answers
SOURCE: Where is the driver side power window cicuit breaker.
check the wireing to the window motor an at the conector as well where it comes thru the door =- i have seen them break there an its covered === also check the circuit breaker in the fuse pannel position number 16 in the breaker for the window motors ok
dennis
Posted on Dec 12, 2008
  • 44260 Answers
SOURCE: Engel model MT45F-G4-S WORKS ON 12 VOLTS BUT NOT ON 240 VOLTS
Perhaps a blown fuse.
Posted on Jan 13, 2015
  • 1162 Answers
SOURCE: My gold engel fridge stops working when battery gets down to 9 volts...how do I stop this safety feature...I have duel battery system and would rather it run right down.
You have a nice refrig. But, the safety feature is there to protect the battery. A 12 volt battery should really never be brought down below 9.6 volts. The reason is the battery cannot sustain a lower voltage without damage to its ability to recharge. The cooler cant run on lower voltages as well so it shuts off. It is all based in the science of battery technology. So be happy it dows cut off or you would purchasing more expensive batteries. Take care of your cooler its a nice one.
Posted on Jan 28, 2015
Jan 28, 2015 | Engel Refrigerators
Mt27f-u1 12v not working
Try tracing the wires from the 12 volts plug to the other end of the wires. You might find a broken conductor or a blown fuse in there.
Aug 26, 2008 | Engel MT-35F-U1 34 Qt Portable...
Works on 12v, but wont work on 240 v?
Does not make any sense that it works on 12 volts, but not on 240 volts......why would you try it on only 12 volts? How do you hookup just 12 volts? with the use of a rheostat? Are you trying direct current or alternating current?
Aug 11, 2014 | Engel MT45F 43 Quart Portable Refrigerator...
Dometic manuals
model could only run on 12 volts see schematic on inside if no 12 volts when plugged into shorepower check switch or check convertor
May 30, 2014 | Dometic Refrigerators
My old Engel won't work on 12v but it runs fine
By the way , What is a Engel? New or old? Desktop or laptop?
Dec 09, 2012 | Computers & Internet
Hi I want to purchase a AC DC 12watt Power Adapter for my old ARTEC 1236P Scanner. Can someone tell me if I can use my spare Input 230V ~ 50Hz 9W (Output - 12 to 9v) adapter? If not what should be the...
This will mean the input on the first device is 120 V and input on the 2nd device is 230 V. Right? If so Yes you can use this if it belongs to the same scanner however you will have to plug the power into a 230 V Circuit. You cannot adjust, manipulate, change the Volts/Watts/Amps under any conditions. If the 203 V (Out put) plug is the same as the 120 V plug and there is a place to plug it in to the scanner then go for it. Volts/Amps/Wwatts/AC/DC are very specific to a specific device.
Jul 24, 2011 | Artronix Technology Artec 1236 P Flatbed...
How much Power is Consumed by your Engel 12-Volt Refrigerator Freezer?
Refrigerator setting (minimum) and freezer setting (maximum - running continuously) the Engel 12-Volt Refrigerator Freezers use approximately 0.9 - 3.9 amps for the smaller units to 1.4 - 3.6 amps for the large 84 Quart MT80 unit. Basically your Engel 12-Volt Refrigerator Freezer uses less power than most 12-Volt coolers 1/2 their size. See our Engel Technical Chart for your particular 12-Volt Refrigerator Freezer.
Aug 12, 2010 | Bosch Refrigerators
Refrigerators Logo
26 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
