Question about Lands Phones
My phone model ST118B does not ring. - Lands Phones
How to I change the number of rings before the answering service cuts in. I want 5 rings getting 2 rings
The following works for the Uniden models
D1680, D1481, and similar phones:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Ring Time"
press [select]
scroll to the ring-count you want to use
( 2, 4, 6 rings or 'Toll Saver' )
press [select] (chirp) press [END]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
Apr 14, 2016 | Uniden Cordless Phone
How to increase the number of rings on answering machine
press [menu]
press [select]
press [select]
Increase number of rings from 14
The number of rings is controlled by the answering machine, not the phone. What make and model answering machine do you have on your phone line?
Oct 30, 2013 | Uniden Cordless Phone
How do I program the message button?
Press Save and follow the prompts. Select the "Messages" button when prompted "Save To?".
Mar 16, 2011 | Fanstel ST118B Corded Phone
How do i make my phn ring longer then it is now
The length of the ring depends on the model of phone, however, phones will come with different sounds that you can select from. These sounds that come with the phone are preset in length and cannot be changed. If your phone has a place to download ring tone, commonly shown as an option of "get new ring tones" in the menu of your phone, then the ring tones may be longer then the one you have. Another option for a longer ring tone is if the phone allows you to add you own songs by connecting to your computer, which would be done by a supplies cable, or by a memory card. However, not all phones allow music that is added to be used as ring tones. Finally, the ring of your phone will continue to loop until the caller has stopped calling. If this is not the case, please tell me what model of phone its is you have so i can look further into it.
Thanks
Mar 07, 2011 | Samsung Cell Phones
Fanstel ST-250
Fanstel sent me the user guide.
Jan 11, 2010 | Fanstel ST118B Corded Phone
Uniden cordless: Adjusting ring tone volume down
If it is like mine....push on one of the volume buttons (up or down,doesn't matter) and the phone will ring. WHILE IT RINGS, push the button again and it should scroll to the next ring option. Keep pushing WHILE it rings to scroll through the ring options.
May 14, 2009 | Uniden Cordless Phone
Phone rings 6 rings before voice mail picks up
Sure. If you had bothered to mention which model you have.
The same internet where you found fixya can also be used to find memorex.com.
How about this? http://www.memorex.com/manuals/MPH6990-03OM.PDF If your model is the 6990 or close, you press MENU 3 times and can set the rings to 2,4,6,8 or tS which answers on the 4th ring if you have no messages or 2 rings if you do.
Carl
Oct 25, 2008 | Memorex 900MHz Phone
Does not ring
is the ringer on the base or phone on? check that first.if that's ok, then plug a regular corded phone into the phone jack and see if there is dial tone.if there isn't any, try other jacks in the house. if still not working, call your phone company.
wg
Feb 11, 2008 | GE 27998GE6 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
