Question about Deadbolt Locks & Locksmithing
I have a touch-bolt series electronic deadbolt model G5X2D01BB need to know how to cancel all my cods out of it please
4 Suggested Answers
  • 257 Answers
SOURCE: reset drum cod
The codes are C Auto C Auto display off, press 24 print 7 print , 00 will display then press C twice.
Posted on Jul 01, 2009
  • 9 Answers
SOURCE: I have a 907 Powerbolt Touchpad Electronic
Take the back off of the deadbolt where you install the batteries. The instructions are inside.
Posted on Jul 07, 2009
kevin_getz
  • 1031 Answers
SOURCE: replace electronic touch pad on model esa3156 air conditioner
You need to remove the screws holding the grille assembly in place. Once you have the grille removed, you will see the access to the touch pad.
Posted on Apr 18, 2012
I can't figure out how to remove deadbolt since it doesn't have any svrews
I think you may have a friction fit type of deadbolt. Remove the door knob or the knob you turn to slide the deadbolt. There should be a shaft that comes out with the knob and was sticking through the inside part of the deadbolt. Now pull the deadbolt straight out, you probably need pliers for this part, be gentle so you don't take the finish off the bolt. I hope this helps, if it doesn't then I may need more info.
Sep 24, 2015 | Deadbolt Locks & Locksmithing
Removing carbine 4011 deadbolt
remove the screws with proper screwdriver then perform the replcment
if u need any details
Oct 04, 2008 | Deadbolt RF Remote , Satin Nickel
Garrison
The manufacturer has a video for installing the electronic deadbolt, it might be helpful.
https://www.youtube.com/watch?v=UZ0nsArpesc
English vision
https://www.youtube.com/watch?v=SqAP2Jgd9n8
French vision
Should you still experience difficulty, please return to your store.
by
CanadianTireTeam
- CanadianTireAnswers
1 month, 2 weeks ago
May 18, 2014 | Locks & Locksmithing
When locking or unlocking using the power it attempts to over throw the bolt 3 times which produces a clicking sound. Deadbolt works fine with key and does this when unobstructed with door open even.
This sounds like an unusual problem, but your lock may be covered under warranty. Warranty covers mechanical and finish defects, but not the internal electronics. I recommend calling them-- call 1-800-327-LOCK (5625) in the U.S. and Canada.
Here is a link to Kwikset's website for your reference, and you can follow a link to their written warranty, etc.:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Aug 15, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I replaced batteries as wouldn't work today. deadbolt will not operate, nothing works. these are brand new batteries. CXan move deadbolt but have to do so manually.
Kwikset has a lifetime mechanical and finish warranty. Contact them from here:
Dec 21, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Brought new keyless dead bolt. Put it in a door that opens in with hinges on right side. The problem is that the motor wants to turn the dead bolt the opposite direction, unlock extends deadbolt,...
My lock adjusted itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Aug 25, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Our powerbolt does not work well in the cold. It appears as if the batteries no matter how fresh, are not strong enough to turn the bolt. I thought I had seen a new model where the keypad simply unlocked...
Batteries, when they are cold, do not give off the same amount of power. You can test this by putting them in a freezer for a few hours and then trying them in a battery operated device. They cold does not hurt them, and they will work fine once they warm up. Depending on how cold the batteries get for your deadbolt this could be the problem. Also if the deadbolt is rubbing at all against the lock plate it could put unnecessary pressure on the motor. Schlage does make a deadbolt system that uses a keypad and a manual turn. The Camelot or Plymouth models.
Dec 16, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Need to disassemble deadbolt with concealed screws
If it's like my deadbolt, pull the inside faceplate off. It's just pressed in place and the screws are behind it.
May 30, 2009 | Kwikset Powerbolt/Electronic Deadbolt-...
Locks & Locksmithing Logo
123 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Bill Boyd
David Belitz
David Belitz
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
