Question about Irons
I plugged in my iron it is not on the off mode and nothing-this is a fairly new iron
Sunbeam iron won't heat up. What's wrong?
Probably heating element failure
Jan 13, 2018 | Sunbeam Irons
Iron is plugged in but no red light no heat no nothing
Oct 10, 2016 | Irons
My gravity feed iron won't turn on.
Your brand new iron probably is defective. Funny how no one wants to have anything to do with repair or replace. You may have to get another iron that that works.
Feb 01, 2014 | Irons
My Rowenta iron was working fine the last time I used it. I plugged it in to use it today and nothing. The little red light on top comes on but the light on the side to let me know it is ready and hot...
Yes there is a solution, I have a DG580 with the same problem. I had to replace the electric cord which cost $17.00 and took 30 min to replace and now works like brand new.
Dec 02, 2010 | Rowenta Irons
Nothing happens
Check the cord feed onthe part when it comes to the iron sometimes there got cable broken on the inside
Jun 03, 2010 | Rowenta DX-8800 Iron
I plug it in...turn it on...nothing happens
I have a Rowenta commercial steamer.It was working just fine then
in the middle of steming a garment the steam was not coming out
at all. It is a new machine and is not used to excess. Please advise
Oct 10, 2009 | Maytag MLI7000A Iron
I have 1700W Rowenta Focus and it is fairly new and water won't stay in it. I pour water in and leaks out all around the sole of the iron. What is going on? It never has been dropped, fallen off anything...
Possibly one of two problems.
1. Water tank has a hole in it.
2. Filler tube that go's into tank has come off.
If you are handy and have the correct type screwdriver bits, you may be able to open the iron and have a look.
Other wise it's bite the bullet and buy a new one. Wallmart or similar do some quite good cheep electrical stuff.
Aug 06, 2009 | Irons
When plugged in iron will not "turn on." If shaken it will sometimes turn on then shut off again. Appears to be an auto shut-off problem.
Could also be a break in the supply cable inside the cable guide
The cable moves during ironing and as the cable guide is fairly rigid , the inner cable gets stressed and snaps
Try waggling the cable instead of shaking the iron
Jul 06, 2009 | Rowenta DZ1700 Iron
I have a Rowenta 1700 iron. The iron has started to act up. When I plug the iron in it just flashes & does not get hot. It is like it is in the stand by mode when you leave it on & don't iron...
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Oct 14, 2008 | Rowenta DZ1700 Iron
Brand new rowenta professional won't heat
The mostly problem in that case is the internal terminal from cord to iron is loose ,open it and fix the the terminal cord to iron,or go to the nearest shop to repair that.
Thanks & good day,
Feb 12, 2008 | Rowenta DZ1700 Iron
Irons Logo
51 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
