Question about Garden
Kohler ph-xt675 self propelled...starts right up then 20 minutes or so stalls out....takes another 20 to 30 minutes before it will restart...i was thinking auto choke but im not sure
SOURCE: 89 wrangler get warm won't idle the takes along time to restart
These jeeps are carbeurated, with heavy emissions systems forced down the throats of Jeep. There are insane Vacuum systems that are too complex to deal with. What I did, (I have the 4.2L) was go out and purchase the Weber kit. I am not selling the part for them, I am actually a happy owner. Mine would die every time I came to a stop. I swapped out the junk and popped in the Weber. I have had no carb problems what so ever. I even eliminated the messy vacuum system! I payed about 200 bucks on Ebay, but from Weber direct they cost around 300. Good luck!
Posted on Dec 21, 2008
  • 246 Answers
SOURCE: lawnmower stalls out
Hello:
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
SOURCE: my 1993 buick century will start and run great for
sounds like the crank angle sensor. my 1993 buick was doing the same thing. hope this helps.
Posted on Dec 13, 2009
  • 61 Answers
SOURCE: Honda Harmony mower starts but will not stay running
rebuild the carberator. easier said then done huh. anyways, thats your only soluation. hope this helped you
Posted on May 29, 2010
goldenglove1
  • 144 Answers
SOURCE: 22 In Craftsman Self propelled.Starts
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Posted on Aug 05, 2010
Huskee 173 cc OHV 21 inch self propelled mower wants to stall about 20 minutes after starting... Runs rough for the rest of the time.
It sounds like a bad ignition coil and/or condensor or ignition module. If you leave ANY gas in these 4 cycles without a stabilizer, the fuel will basically, turn to varnish and plug the main jet in a carburetor, also.
Apr 26, 2014 | Garden
1988 buick regal stalls and restarts stalls and restarts
Sounds like a relay or coil failing.
To proceed you would need to find out if you are loosing spark to the plugs or fuel pressure to the injectors when it won't start.
Sep 22, 2012 | 1988 Buick Regal
WONT START TORO PH-XT675-2011 USED ONLY 5 TIMES
You have to take carb off and remove bowl with #10 wrench then look in that tube and unscrew ur jet in that tube and get a sewing needle and push thourgh jet hole .
Aug 26, 2012 | Toro Garden
My poulan pro 6.75 self-propel mower stalls frequently
Replace the coil. Remove the top cover so that you can see the flywheel. There will be a horseshoe shaped peice with the plug wire attatched to it along with a small whir plugged onto it. Remove the two screws holding it on and unplug small wire and disconnect plug wire. When you put the new one on place a business card between coil and flywheel, this will give you the proper spacing, reconnect small wire and plug wire, reassemble top covers and you are good to go.
Aug 14, 2009 | Garden
Car stalls when oil pressure drops...20 minutes to restart
No it is a fail safe. When your oil pressure drops below (on most cars) 30 psi your computer will shut your fuel pump down until you either let it sit for a while and it resets or until oil pressure builds again. Sorry!
Mar 11, 2009 | 1992 Buick Roadmaster
2002 craftsman 23 hp kohler pro series stalls and wont restart
try playing with the throttle adjustment or it could be a saftey feature malfunction, like the seat shutoff for example.
Feb 25, 2009 | Craftsman Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
