Why can we not log into prodigy - Washing Machines
Scottsman prodigy icemaker max harvest time codes-common causes.
my prodigy periodically flashes 2 which indicates slow harvest what does this mean?, is it common for time to time to flash 2, how do I correct it
Mar 14, 2012 | Scotsman Prodigy Air Cooled Cuber C0330SA...
My prodigy does pump out water.
Could be a shoe strang in the pump. Or a coin. Remove the front panel and inspect the pump for obstacles. themobilian_129.jpg
Nov 12, 2010 | GE Profile Prodigy WPSE4270A
GE Profile Prodigy will not drain water out. It starts and then stops after about a quarter of the water is drained out
Check your hoses to water pump,appears to be a restriction. Have a shallow pan and towels to collect water
Oct 24, 2009 | GE Profile Prodigy WPSE4200A
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
My datamax prodigy plus wont print out a word doucment
You need to download the Windows Drivers from Datamax Website, you can then use the printer with all Windows based applications
Apr 13, 2008 | Datamax Prodigy Plus Thermal Printer
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
