Question about Garden
Powermate tiller ran for 15 minutes let off gas and died. Cannot get it back running.Tried starter fluid no luck
cartersintn
  • 62 Answers
SOURCE: 1995 BUICK LESABRE WON'T START
bad fuel pump, or fuel fuse/relay check fuse or relay first
Posted on Sep 27, 2008
SOURCE: COLEMAN powermate 5000 generator w/a Subaru engine
Check the vent in the fuel cap to make sure its free to breath. It could be creating a vaccume in there and starveing for fuel. Maybe run it with the gas cap off and see if the problem gos away.
Posted on May 06, 2009
zr800o1le
  • 19 Answers
SOURCE: 2006 Arctic Cat ATV dies after about 15 minutes of riding
It Sounds like your Stator is going bad.
I would have it checked/Diagnosed by a Local Shop.
Posted on May 12, 2009
mkv0525
  • 358 Answers
SOURCE: Hyundai Accent stalls and won't restart for 15 - 30 minutes.
check to see if you have fuel pressure after it dies. fuel pump could be getting hot and shutting off.
Posted on Jun 11, 2009
al_kupchella
  • 843 Answers
SOURCE: i cant get my coleman powermate 5000 MAXA ER to
It's almost certainly gummed up gas in the carburetor. Get some carb cleaner, and some spray instant start. Drain the gas from the tank and put a small amount of 50/50 carb cleaner and gas in the tank. Remove the air cleaner, open the choke, spray a little instant start into the carb and start it. It may fire just a couple of time. Keep the choke on to try to pull a bit of gas through the carb. You may have to do this a few times. Once you can tell some gas is flowing, open the choke slowly to keep it running until you use up the 50/50 mix. Then try a small amount of straight gas in the tank to be sure it works right, before you refill the tank. Make sure you use a stabilizing additive in any gas that you store for more than a month. good luck, Al K
Posted on Feb 02, 2011
Tiller won t start
The fact that it started for any length of time, tells you the engine functions. The engine is STARVED of fuel mixture. Either the inside fuel line is clogged and needs to be blown out or the carbonator adjustment is incorrect. Check to see that the spark plug GAP is proper and when placed back into the engine it is hand tight with the spark plug wire formly in place.
Mar 01, 2014 | Husqvarna Garden
I bought this tiller off Craig's list. He was up front and told me he had use starting fluid to get it started but that it ran after that. I brought it home started it (via starting fluid) went to the...
your carburetor needs cleaning &,or otherwise before this, try removing the "sediment-bowl" located under the carburetor,needs removal and checking for water and dirt in this bowl and possibly new gasoline in the gas tank, if contaminated with water/dirt after purging all lines after this
Apr 01, 2011 | Briggs & Stratton Garden
Tb144 troy bilt tiller, starts and idles fine, after it warms up, you can give it gas and it runs fine. when you let off the gas and return to a idle, then try to give it gas agian, it will die. then it...
Sounds like you have a dirty gas problem.
Empty the tank and remove it, clean it out and before refilling filter the gas to remove contaminants.
If this fails the problem is the carburator.
Remove it and disassemble and allow the body to soak in gasoline for about 15 minutes. the blow out all the port with compressed air and reassemble.
It doesn't take much to clog up those litte carbs.
Jan 31, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
Coleman Powermate generator will not start.
Changed plug since last year?Choke adjustment? try premium gas?
Aug 13, 2009 | Electrical Supplies
Get your motor running
Check to see if the gas cap is clogged. If the gas cap is clogged, it will keep the carburetor from getting the proper gas flow. Try this: The next time it begins to die, loosen the gas cap. It should begin to run again. If it begins to run again, then you know it's the gas cap.
Jim
Jun 06, 2009 | Mtd Products Yard Machines 158CC Tiller
Sounds as if the gas tank is not breathing properly. The next time you run it, when it's about to die, loosen the gas cap. It should begin to run again. This is a sure sign that your gas cap is clogged. Clear gas cap of debris, or buy a new one.
Jim
May 30, 2009 | Swisher Atv Tru Plow
Feb 27, 2009 | Coleman Powermate Subaru 5000W Portable...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
