Question about Freezers
My freezer MFU14F3GW2 started kicking the breaker. I tryed another breaker plug and it kicked that one off as well. Any ideas
  • 636 Answers
I would think that the motor has seized on it
Posted on Jul 25, 2009
How to fix freezer power kick off
Are you referring to the defrost timer or a circuit breaker ??
Jun 01, 2014 | Freezers
Mfu14f3gw2 wiring diargram
Good Morning Jon - The best way to locate a Wiring Diagram for this particular unit, MFU14F3GW2 is by visiting the manufacturer website. The Owner's Guide and Parts Manual are also available. Hope this information is helpful and if there is anything else that I can help you with, please feel free to reconnect!
Jun 09, 2013 | Frigidaire Freezers
Red light blinking with audible alarm. Compressor
That is the compressor starting relay trying to start the cooling cycle and the overload protector kicking off. You can try installing a new start device for about $50.00 but you are most likely looking at a compressor replacement which runs about $400.00
Sorry for the bad news
Apr 17, 2010 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezer won't kick on
That is the overload protector on the compressor. Keep the door closed to preserve the cooling you have from the frozen food. Leave it unplugged for about an hour. Bang on the compressor with a rubber or wooden hammer then plug it back in. If it does not start you either need a new start relay or a compressor.
Apr 15, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
Condensing unit terns off but won't come back on kicks off breaker
If it runs, turns off, then tries to restart and kicks breaker, look for bad start components. Check start relay, start capacitor. It may be trying to restart too quickly and the compressor over amps and breaker trips. The system needs to have at least 3 minutes of off time before trying to restart. This allows the pressures in the system to balance enough so the compressor can overcome the high side pressure and start. I've seen where people turn the control up and down very quickly causing the compressor to over amp and trip breakers and over loads.
Hope this gets it for you.
Oct 22, 2009 | True 19 cu. ft. / 538 liter Commercial...
Everything works fine, except when the compressor kicks in the panel breaker trips.
Most likely a short in the compressor electrical components (relay, overload,capacitor) Supco makes a 3 in 1 that you could use. If this works fine, if not "bad compressor".
May 27, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Freezer Just Stop Working
You should not run your freezer from a strip plug, only from a wall outlet. It is OK for a small spark to occur since the freezer is trying to start the compressor as you plug it in. If there is a big spark that kicks out the circuit breaker if you plug it into a wall socket, then there is a short in the compressor or light circuit in the freezer. A strip plug in probably will not have the capacity to run the freezer. Plug it into the wall socket and try that. If you have a circuit breaker kick out, then it's your appliance. Hope this helps you, Rick
Apr 25, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Breaker tripping?
It looks like your compressor is the problem , you can try to put a starting kit if it doesnt work you will have to change the compressor!
Francois
Nov 14, 2008 | Freezers
Kenmore Freezer 20.3 cu.ft. won't kick on
Poor mom..:) You need a technician for that problem. But much better if you buy new one because your unit is already 14 yrs old the labor and parts are expensive. For this problem I think the compressor is already burned or stuck up.
Jan 04, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
77 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
