What is this error code on my furnace "ec" - Heating & Cooling
    New Friend:
  • 10 Answers
We would need brand and model number to help you.
Posted on May 14, 2017
5 u code is on how to fix it
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Here are error codes found on many York, Trane, Luxaire, Lennox, Carrier, ... If younotice 5 red colored flashes on your York Furnace, it signifies that your
Oct 03, 2015 | Cars & Trucks
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
EC ERROR CODE
It means the unit is low on gas
May 19, 2014 | Midea Heating & Cooling
When i turn on my ac it looks to be working but 10 to 15 min later no work any operation and disply shown EC.
My is problems this is the mc indoor unit display by the EC errer code that a problem plz the help
May 07, 2014 | Midea Heating & Cooling
Furnace error code 42
have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 12, 2014 | Heating & Cooling
Brand New Ducane Furnace with Multiple Error Codes
Check your drain line. It appears that water is not draining and backing up into the furnace. Is there a drain trap? If not or if there is no vent on the drain line there can be a vacuum created when the furnace is running and it actually pulls water back into the furnace and when the inducer shuts off it releases the vacuum allowing the water to drain.
Dec 17, 2012 | Honeywell Furnace Air Pressure Switch...
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Our Bosch 2400E NG tankless water heater is displaying the EC code. I've checked the ionization electrode (rubbed it with a pencil eraser as instructed once before when we had this problem) and I also made...
Had same problem on my five year old water heater (ec error). Didn't figure it was a gas supply problem after five years but double checked to see if the gas bill was paid. It was.
Cleaned the contacts on the two sensors that are clamped to copper pipes inside. Still had error after powering up. Held the error button in for about five seconds, and the blinking EC code went away.
May 21, 2010 | Bosch AquaStar 2400ES-NG
2400es blowes out flame error code ec
there is a
part caled hot surface ignition its a coil that glows dark red in order to ligth the furnace if its craked it wont work if its not craked it plugs rigth on to the computer board on the unit try umpluging it and take a ac metter test the to prongs you should have 24 voltscoming from there when you call for heat if there is voltage there then you could be sure that the hot suface ignitor is faulty
May 28, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
