Question about Miscellaneous
Our turn of the century ceiling fan which has a remote control. The fan works with adjustable speeds, but the light will not.
The light it self made a slight noise for a few days, then started turning off by it self. Now it will not come on at all. I replaced the bulbs and checked for loose wires.
  • 3,054 Answers
Sorry to hear that... anonymous,
"turn of the century" Brand: Ceiling Fan w/Remote.
I checked around and your fan seems to be a newer
(inexpensive) model FIXYA has yet to categorize...
My first impression ...
>> Buy another & keep the old for parts
For more expensive units...
that justify the cost of parts, shipping & labor
If they don't have the parts...
they can CERATAINLY TELL you where to get them
(if they exist)
Casablanca Fan Parts
Posted on May 14, 2017
  • 1,028 Answers
What model of vehicle is it car or truck? let me know and i may be able to help
Whirlpool gas oven light bulb lasted 5 years but now keeps burning out?
all appliance bulbs are not created equal it needs to be specifically an oven bulb to take the heat .
Feb 14, 2016 | Whirlpool Accubake 30" Self-cleaning...
How to fix ceiling fan light
Make sure the light wire is connected to the receiver & bottom of fan.You should set the light to the on position when using the remote and leave it that way.
Sep 10, 2015 | Hunter 52" Ceiling Fan With Light And...
I have a samsung HLR6167WX/XAA dlp tv. I replaced the bulb, it worked for 1 day and didn't turn on the next day; no lights, no noises, nothing. So then I just replaced the ballast, still nothing.
Have you reset the lamp time after lamp replacement? If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 10, 2013 | Televison & Video
Driver side brake light issue
Consider the posibility that the replacement lamp is being installed backwards. It can be done and the resulting effect on performance will be as you describe
Feb 12, 2013 | Cars & Trucks
Samsung DLP brightness pulsating
Try to reconnect all connectors specially to the connection of bulb and light engine assembly..
Hope it helps..
Feb 23, 2012 | Samsung HL61A650 TV
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
I purchased a Turn of the Century 52 inch remote ceiling fan, model 355-6786/6787/6788. After installing it I couldn't get the high speed button on the remote to activate the high speed on the fan. All...
I purchased a 'Turn of the Century-Apollo' model 355-6786 cieling fan. The only problem is no fan blade mounting bolts and nuts, instead I have 2 packs of mounting screws. I've dialed the Customer Service Department to no avail. Is there an unpublished WEB site?
Jun 26, 2010 | Casa Vieja Turn of the Century Antique...
I have a hampton bay ceiling fan which will only run on the fast speed. I have changed switches but still only the fast speed. I have touched each wire to the load wire to see if it was the swith but no...
Hello Brother,
Hang your ceiling fan on the Quick Connect fan bracket and wire the ceiling fan according to the manufacturer's instructions. The three wires coming from your ceiling should match the three wires coming from your ceiling fan: black (positive or hot), white (neutral or negative) and green (ground wire).
Use the high, medium and low keys on the remote to adjust the Hampton Bay fan speed, then use the light key to dim the light and the off key to turn off the fan.
For REMOTE CONTROL FANS you cannot use with any variable speed or slide wall switches. The remote control function must be used with on & off switch outlets only.
Speed Controls Click here Capacitors Link
I hope This Helped you,Thanks for Contacting FixYa...
Apr 22, 2010 | Hampton Bay Heating & Cooling
We have a Turn of the Century ceiling fan 60
try google or goto a fan&lighting store the should be able to match up that part let them know how many speeds it has it makes a difference ps they can be a pain to reinstall
Apr 13, 2010 | Casa Vieja Turn of the Century Antique...
Miscellaneous Logo
48 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
