Question about Ovens
Do I put the probe in the meat and close the door on the wire?
What is the meaning of f8 error code
shorted meat probe:
the problem could be with the probe, or probe circuit. check the probe look for pinched wire or condensation on the probe receptacle
Dec 14, 2015 | Ovens
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Could you tell me what error code 003 is for a zanussi zbd 903 built in double oven
This code is displayed when the user attempts to restart the appliance after an
error code 001 or 002
- Safety circuit malfunction
001 if the meat probe is open circuit or the temp of the food is over 100deg c
002 is if the meat probe is short(closed) circuit hope this helps
Jul 11, 2010 | Zanussi Ovens
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Has an f-8 on dislay oven won't work
F8 Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle
Mar 15, 2010 | GE 24" Built-in Single Electric Wall Oven...
My oven is stuck in probe mode and will not cancel.. what should i do
Measure the resistance of the meat probe on the K-ohm setting. If it's open, then the probe is bad. I'm not finding a spec on the resistance but it should be something in the K-ohm range.
Next stop is to check the meat probe socket. May be gunked up with condensed grease or whatever. Sometimes a light schmear is all it takes to flake it out. Then check continuity from each leg of the meat probe socket back to the ERC, where the meat probe harness connects.
Mar 06, 2010 | Ovens
Oven code e1 f4
HI. This code will indicate that there is a fault within the meat probe device.
The Problem could be with the probe, the receptacle, or probe circuit. Check the probe for faults. Look for pinched wire. Look for condensation or contamination on the probe receptacle. Replace probe if all else checks out ok.
Jan 08, 2010 | Whirlpool Ovens
What is a U80 meat probe error and how do I fix it?
Error U80: Shorted meat probe
1) Food, moisture, or other substance is in the socket or on the oven connection end of the meat probe. Check: Verify proper operation with new probe (replace probe). If still fails with new probe check wiring of housing to eliminate shorting to sheet metal. Solution: Clean socket and meat probe.
2) Bad meat probe (shorted). Check:Use new meat probe to test for correct values in the service screens. Solution: Replace meat probe.
3) Shorted socket or wiring. Check: Test socket at connector J20 on relay board. Solution: Replace meat probe socket.
Functionality when error U80 reported: Cooking and cleaning are available but meat probe options will not be available.
User action/solution:
1) Verify oven connection end of meat probe is clean and no food, moisture or other substance in is the meat probe socket.
2) Call for service.
Aug 26, 2009 | Dacor Epicure EO230 Stainless Steel Oven
Kitchenaid single oven, error code is a picture of a push pin
its a "meat probe" not a pushpin. somehow the unit thinkd you hae a meatprobe inserted, soundslike a short in the meat probe jack( usually happens in high moisture areas, the wires swell and make contact with eachother, the replacement jack, has better insulation around the wires, you could also disconnect the wire harness from the main board assy(behind the console, if you never use the function!
Jan 29, 2009 | KitchenAid KEBC101 Electric Single Oven
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
