I tried to get at the latch by sliding an allen key between the tub and door and lift or move the catch but am unsure how the latch mechanism works. Any suggestions other than using a crowbar to force it open. This is a very plain model about 8 years old and there are no electronics or test cycles that can be run.
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
SOURCE: Oven door stuck on locked!
E1-F5 indicates door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method next time...
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Remove the motor and unhook the rod from the motor cam. If it is a built-in over, sometimes bending a coat hanger into a hook and sliding from the right side into the lock you can unlock the door.
SOURCE: GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
SOURCE: Maytag Model # MDB7600AWW door will not latch
double check door latch make sure connections are proper if right and still not working probably main board and panel
SOURCE: dishwasher door will not open.tried
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
