Question about Toyota Sewing Machines
Toyota RS2000 Bobbin Winder Unit Replacement?
I wonder if anyone could help.. I have taken out my broken bobbin winder unit and a small spring was attached. Now, when I put my replacement part in, I can't figure out where the spring should be positioned in the mechanism. Does anyone have a photo or diagram of the spring and bobbin winder in position for reference?
  • 374 Answers
SOURCE: bobbin threading
hi! well! everything is gonna be fine,make sure the thread was wine on clockwise rotation as shown on figures if this similar to your bobbins anyway this is just a sample how to set up bobbinsf1d210b.jpgthe thread is inserted on slot of bobbins case to acquire a tension tread. then hold bobbins on spindle while the needle of machine is on higher shown on figures2320d1b.jpgthen inset this on shuttle hook case as shown on figures.d60bb50.jpgthen after bobbins was set up on shuttle case the thread of bobbins will hook up by the thread of needle by rotating the handwheel manually by your hand be sure the top thread was set up properly.just let me know if the procedure can help.
Posted on Mar 25, 2009
  • 980 Answers
SOURCE: singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
Posted on Nov 22, 2009
  • 191 Answers
SOURCE: bobbin stuck on winder
Sounds like you need to remove some thread off the bobbin to get the pressure off. Sometimes if you wind too fast or you have a poor quality thread, the thread will stretch as it winds and causes to bobbin to compress onto the winder shaft.
Good Luck!
Posted on Jun 16, 2010
  • 13 Answers
SOURCE: 1320 will not thread bobbin
probably needs to be cleaned. the oil gunks up from lack of use with time.
Posted on Feb 21, 2013
Testimonial: "Thanks again Pajarita! Great troubleshooting skills! Your remedy worked perfectly! Anthoz"
  • 243 Answers
SOURCE: Bobbin will not thread
It may be an alignment problem with the thread guide and the height of the repaired winder.
Posted on Feb 07, 2014
I need replacement "bobbin winder complete" for the one I broke on my Thompson Mini-Walker PW 201. Does anyone know of a source for it? Also I need a manual for this machine.
If you are unable to replace the bobbin winder for your machine, you might check the local fabric stores for a stand-alone bobbin winder. Last time I checked, they cost around $20-25. They are nice to have because it saves wear and tear on your machine.
Simplicity SideWinder Portable Bobbin Winder
Apr 13, 2015 | Sewing Machines
How do I fix my bobbin winder?
1. Take the top off.
2. Check to see if the bobbin winder has pressure as you move it back and forth. There should be. If not then check for a spring connected to the bobbin and reset it. There will be some kind of post to hook it to.
3. Place the bobbin winder in the "off" position and put the top lid back on.
4. Without putting the screws back in move the bobbin winder to the "on" position and to the "off" position.
5. There should be pressure either way you move the winder.
6. Loosen the hand wheel handle.
7 With the bobbin winder in the "go" position use your foot pedal to make sure it revolves.
8. Replace the top.
Dec 01, 2014 | Sewing Machines
My bobbin winder will not turn and wind the bobbin. I have taken it to a reputable repairman and he says the bobbin-winder motor has a loose pully but there is no way to get inside to fix this. Help!
Why not just buy a stand along bobbin winder device then. They are pretty common, you can get one from this website.
I have seen them cheaper than this too I think. Certainly solves the problem, just wind the bobbin on this.
Sep 02, 2011 | Euro-Pro Shark 9110 Sewing Machine
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Mar 13, 2010 | Kenmore Sewing Machines
How to fix bobbin winding
. Put the spring on the hole that the bobbin winder fits into. Now put the bobbin winder in, but don't tighten the screw- just turn it once or twice. Put the straight projection of the spring on the right side of the bobbin winder. Start to tighten the screw. Before you get the screw too tight, pull the downward projecting side of the spring over the housing of the machine so that it is pressing on the inside of the machine creating a push to the left. Center the circular part of the spring underneath the screw and the bobbin winder and tighten up.
Jul 15, 2009 | Euro-Pro 473
Bobbin doesn't fill in bobbin winder
The bobbin winder question is a frequent one and it is very easy to solve. If you look at the shaft where the bobbin sits on the bobbin winder, you will notice that it has a slot in the middle of the shaft, an opening if you will. This is where you use a flat screw driver and open that space more to give more friction to the bobbin so it is not loose on the shaft. That slot was made for that. There are different bobbins on the market so thats why the slot is there. If it is too tight, grab a pair of pliers and close the gap. The metal of the bobbin winder on that shaft is malleable exactly for this reason. No need to put plastic bag material or anything like that. Use it as it was intended for.
Jul 07, 2006 | Yamata FY14U4AD
Sewing Machines Logo
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
