How can I access my account, see numbers of my ads, how do I get help?
Tip
Yahoo customer care helpline number
Not able to add a folder to your Yahoo mail account according to your preferences? If yes, then you need to dial Yahoo customer support phone number. With the aid of the number, you will get the right aid for adding the folder in your account. The tech expert will guide you the effective method for adding a folder in mail account. On the other hand, a third party tech support providing company is the ultimate option to obtain hassle-free tech support solutions. You can know more about Yahoo tech support solutions by getting in touch with the company's tech professional.
http://www.email-technical-support.net/yahoo-technical-support.html
Now you can easily add an additional layer of safety and security to your Yahoo mail account with two-step verification. With the help of two-step verification you can use both your password and an extra security method to authenticate your individuality whenever you sign in to your yahoo account. In case someone else tries to use or access your account then till they are not able to access your account, even if someone knows or guess your password. With the help of 2 step verification security in yahoo mailno one can be able to get in to your account without using two-step verification.
Yahoo Technical Support Number USA Canada
on Dec 07, 2016 | Miscellaneous
Tip
Contact yahoo help
Start here:
https://help.yahoo.com/kb/yahoo-account
Aug 31, 2014 | Yahoo Mail
I want password of my facebook account to be sent in to my cell number because im no longer have access to my email
not 100% on this but I think you need to have an email account to do this (its an added security measure to ensure its you ) if you no longer have access as you say could you not use someone else to do this..
Aug 24, 2014 | Facebook Apps
How do I get to numbers on Motorola Moto G phone
Connect your Google Account to your phone. Then log into Gmail account on PC and upload contacts to Google Contacts. The contents added to My Contacts will then sync to your phone and stay updated.
Mark
Motorola Support
Aug 12, 2014 | Motorola Cell Phones
How do I reset my facebook password because I no longer have access to the email or phone number I used when I set it up
According to Facebook's Help Menu:
I can't reset my password because I can't access the email address listed on my account.
You may be able to get back into your Facebook account byanswering a security questionorgetting help from friends. To see if you have these options:
  1. Go to theFacebook login pageand clickCan't log in?in the top right.
  2. Fill out the form to identify your account.
  3. Look at the list of email addresses listed on your account. If you don't have access to any of these, clickNo longer have access to these?
  4. Follow the directions provided to answer your security question or get help from friends, if you see these options, or contact your email service provider.
Once you get back into your account you can change your login email address at any time from yourAccount Settings. You can also log into Facebook with any email address you've added to your account.
May 11, 2014 | Facebook Social Network
Created a new gmail address and cannot access it. It says I have the wrong address or password???
Hi Cher,
Most likely, you're using the wrong password. Most times this is because you have accidentally enabled CAPS LOCK when you were creating the account, or you were using the numeric pad whilst it was disabled (hence you didn't type any numbers in the password, although you thought you were). Try to login and use the password you know but enable CAPS LOCK or disable NumLock before you type it (i.e. try replicating what your keyboard status was)
If unsuccessful, either give up the account and create a new one or try calling Google support - but keep in mind they may suspect you're trying to hack into someone's account, unless you know all the details AND you're using 2 way authentication (i.e. you have added a mobile number where you can receive an SMS with a code)
Jan 27, 2014 | Google Gmail
I have been locked out of my account because i added a protected code to my account using my cell phone to prevent others from logging in to my account because my ex-boyfrined tried to access the account....
blm7517, I knew that your boyfriend is the one that hack that. I open your account and say"pls. dont tell my gf". The password was change into 522236974111jhfg. Dont tell it to your bf.
Jun 07, 2011 | Facebook Social Network
Netgear firewall is blocking access to my email account. how do i fix this?
Well that would depend on what program you are using to access the e-mail account and the type of account that is set up.
    OP3 - port 110
    IMAP - port 143
    SMTP - port 25
    HTTP - port 80
    Secure SMTP (SSMTP) - port 465
    Secure IMAP (IMAP4-SSL) - port 585
    IMAP4 over SSL (IMAPS) - port 993
    Secure POP3 (SSL-POP) - port 995
Also check with your email provider and see what port number they specify. I believe yahoo uses a weird port number for added security.
Mar 01, 2011 | NetGear WGR614 Wireless Router
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
